Can recommend. Mine is excellent.Gozney Roccbox is down to £319 at the moment if anyone is considering one.
Tempted to get one to replace my old Ooni 3
Decent kit. Should be able to sell the Ooni 3 via local sale to fund the new one.
Ordered one, my Ooni would need to much of a clean up to have any value
Sounds good, although a proper pizza oven at 400c+ will be knocking a pizza out in 90 seconds, but having versatility is not to be sniffed at.I bought a Masterbuilt mavity 560 smoker grill, it just so happens to be a pretty decent pizza oven too! I don't have the pizza oven add-on, although it works so well without it..
For £390 you do get a lot of versatility.
I've seen people using just oak rather than charcoal, which I'll try sometime. I do have a slight problem in that I broke my pizza stone, and the 14" cast iron tray I'm using at the moment transfers heat a bit too quickly.
Highly recommend it if someone wants an all one solution tho, last weekend I smoked some ribs, took them out, wanged the heating up and bashed out a couple of pizzas (6 minutes each), then turned it down and then got a couple of burgers on the go, pretty neat!
I think I want electric next. My Ooni constantly blows out of its windy which it is a lot. Plus it means I could use it indoors.
Will be firing up the Koda16 for some pizzas later, that’s if the bloody dandelion white fluff dies down!
Done first batch with Roccbox, certainly a step up from my Ooni 3
Roccbox turned up with a small paring chip, they've offered me choice of almost anything on their accessory page
Was thinking of a turning peel but always managed without one, they worth having?
I bought a cover and have a cheap wooded launching peel that works fineYeah, i'd say a turning peel is decent. What about the wood attachment?
Maybe just the cover if you're not bothered about maximising profit?
ah got youSorry, meant the wood ignition basket. That's about the most expensive accessory available, but if it was me i'd get one of the high end turning peels.
