- 19 Oct 2002
- Shakespeare’s County
I can cruise as low as 13mph
My car, my wife's car and my previous car were all a one and done button to set cruise.Eh? As above most vehicles I drive have a minimum speed of 25 MPH to set cruise control, drop out of cruise control if the speed drops below 21 MPH (18 for the Tiguan IIRC) but also none actually have a simple press set done, most it is at least 2 button presses and depending on what I drive some set is pressing a 2 way control downwards, others a 4 way control which may be up or down or pressing it in, etc. so trying to remember what does what is just too much faff.
EDIT: Actually some of the vans it is a simple lever press IIRC but again different implementation so not muscle memory when not driving the same vehicle regularly.
It's car dependent. My wifes car is really not happy in 4th at an indicated 20mph as it's basically idle speed. 3rd is doable but it's still only about 1100 RPM & the slightest touch of the throttle sees the speed creep up to 25ish.Oddly enough I drove through a 20mph area yesterday and found it effortless. 20mph was 1k rpm in 4th, not an issue
I was replying to the previous post simply stating that his experience will not be universal.You think 4th is ok for 20 but blame the speed limit. Really ????
Congrats for working out you need 2nd gear.
Obviously cause he has a big engine car than can sit at 1k rpm unlike a 3 cylinderI was replying to the previous post simply stating that his experience will not be universal.
Obviously, hence why I stated "It's car dependent"......Obviously cause he has a big engine car than can sit at 1k rpm unlike a 3 cylinder
Pointless post then ?Obviously, hence why I stated "It's car dependent"......
Yours? Yeah, I reckon so.Pointless post then ?
It's a discussion about 20mph limits & how much of a pain in the **** they are isn't it? Her car isn't really happy at 20mph full stop unless you want to drive everywhere at 2K RPM in 2nd.Don’t really get it. ‘My car doesn’t like 20mph in 4th’.
Talk about thinking out loud and then thinks anyone cares )
Are people not allowed opinions that you disagree with?
You seem to care, you keep replying.
I’ll ask the kids skull about how much of a pain it is hitting them in 4th rather than 3rd ?It's a discussion about 20mph limits & how much of a pain in the **** they are isn't it? Her car isn't really happy at 20mph full stop unless you want to drive everywhere at 2K RPM in 2nd.
If you can't drive at 20 in a 20 you shouldn't be ******* driving!
