got around to running it but noticing low gpu core clocks when running the benchmark
gpu was oc'd to 2950mhz min, 3225mhz max, ram was running at 2774mhz, +15% power limit
I scored 7 097 in Steel Nomad
AMD Ryzen 9 7950X, AMD Radeon RX 7900 XTX x 1, 32768 MB, 64-bit Windows 11}www.3dmark.com
but gpu core was around the 2.4ghz region, far below what i had set as the base speed, any reason for this or is it a bug?
Mine was with Vulkan so yours seems about right tbh for MBA, what is your undervolt set to?did a vulcan run and got 7262, with oc settings from above
Try a small drop so it won't affect stability, say 1130mV. It helps to sustain higher clocks.not running a under volt, +15% on pwr target.
They need to do it for every graphics card not just the 4090. They’ve got their work cut out if doing manually.Good to see 3DMark taking down the bugged runs but i fear they will have their work cut out .... they need to implement something where it notices a big fps spike and then makes it invalid and will save them then having to manually go through each score .... but at least they are working on it![]()
Do AMD also have this issue ? i thought it was exclusively a 40 series problem as never had anything like this back on the 30 series cards.... i 1st encountered it just after getting the 4090 and running Speedway , the difference being the 1st words out of my mouth when posting the score were this is a bugged run and from then on was like wild fireThey need to do it for every graphics card not just the 4090. They’ve got their work cut out if doing manually.
Hopefully the fix they are implementing will stop all this, they need to apply it to Speedway as well as that is another with bugged scores.Yes it happens with every card if pushed too far.Do AMD also have this issue ?
7900xt
Mem running at 2900mhz
I scored 6 334 in Steel Nomad
AMD Ryzen 7 7800X3D, AMD Radeon RX 7900 XT x 1, 32768 MB, 64-bit Windows 11}www.3dmark.com
4090 scoring near 2X a 4070 Ti when in reality that GPU is only about 40% faster, what it does have is 2X the memory bandwidth.So literally the only reliable results are from AMD and previous Nvidia card gens. Obviously stock 4 series and mildly overclocked 4 series are valid as well but those pushing the memory are getting massively overinflated scores. From reading that thread this is also a problem in Timespy.
