- 20 Oct 2002
- Derby
I use trumotion on smooth when watching movies with fast scenes or panning shots and it works well.
Thanks I have tried it and it seems to have helped. It almost like the pixels don't refresh fast enough.Would a small amount of TruMotion fix that?
Been watching a lot of lot of 80’s films on the g3 and it just keep blowing me away. The amount of detail it’s pulling from the shadows and detail on puppets and practical special effects is superb!After just over a year with the C3 I still absolutely love this TV. It takes me so long to watch a film as I keep pausing and rewinding haha. I sat down and watched Guardians of the Galaxy Vol.3 the other night. These are just snapped on my phone so quality has been lost but man I think the picture is still incredible.
Hold on. You still have the C9 though right?I found smooth still too OTT, with soap opera effect.
Newer models will have better processing.
G4 reviews say the motion is superb now too.Yeah. I think if I were to buy a newer model it would be Panasonic, they're reported to have more accurate colours and better motion handling.
Thanks. No not at all which is quite refreshing. I'll post up the settings when I get a mo for you. Hopefully tomorrow.Looks stunning @Firegod. Have you done much tweaking?
I found a guide on Reddit with recommending settings which I think I’ll follow on Wednesday when I have time.
Unless there are some quick wins.
C4 is a bit brighter in HDR. C4 has just been released so its expensive right now vs what its actually worth. Either take a look at the G4 or stick with the cheaper C3.Anyone know what the difference between the c3 evo and c4 is ?
C4 is more than double the price, is it that much better ?
C3 and C4 have very similar CPUs. Only the G4 has a substantially upgraded chip. This might not make a huge difference but might in 3-4 years, if you use a lot of the inbuilt features and apps. LG will be delivering full OS updates from now on so might be relevant, might not be for your uses.Anyone know what the difference between the c3 evo and c4 is ?
Even better if you can catch them on the deal for £1090C3 are a good price, £1200 for 65"
Hey! So on an an ultra HD blu ray I have that source set to a cinema mode (custom). 16:9 aspect with just scan on.Looks stunning @Firegod. Have you done much tweaking?
