Hi hope you're ok. I followed your guide today, pressed button as directed but without success.Really appreciate your help, thank you, I'll have to try that tomorrow when we are there servicing it between guests.
The engineers who put the meters in both said there was no way to test the Off Peak Power without coming back after midnight!!
I assume the unit has a clock in it with a battery. Is there any way to see what time the Off Peak should come on and go off.?
You don't need to do any of this guessing. Just do what the YouTube video says exactly.Hi hope you're ok. I followed your guide today, pressed button as directed but without success.
Display without pressing anything is R1, First press turns it to all zeros but no stars in the centre. I pressed again and held, but not a sound and it just brings up the meter readings Rate 1 again. I tried it many times, for 30, 60 seconds and more still not a sound and my off peak power didn't come on. I also tried it after each display, but again nothing. I took a video of myself pressing the buttons and the changing display if that helps ?
Hi Ivan,Hi seby
The meter configuration and calibration are two separate things. The clocks on these meters had a habit of drifting over the years though unfortunately. Again you need the meter utility software to correct the RTC (real time clock).
HiHi Ivan,
Is there any easy way I can adjust the RTC on my 5246C myself with an optical 1107 FLAG probe/usb? Or would I need meter manufacturer’s access/login details etc?
It has crept about 20 mins over the last few years as is common.
TIA
As an update I found that the UK ‘metering folk’ periodically test an example of each non-smart old type meter model ‘in the field’ and either keep to its certified date, or lengthen or shorten it depending on the tests - they the update the suppliers. According to my supplier, Octopus, when I mentioned mine was certified to 2026 they came back with its on their system as 2031! Obviously, as long as it still works. They did say that folk with electric heating, including storage heaters, can go on their rate for heat pumps which has 9 hours of cheaper rate. When they looked into it further they found it was the same rate as I get 10 hours cheaper. At least I know if I need to change to a smart meter I can almost get what I do now. They really do seem to be honest and fair, unlike my previous two suppliers years ago…I know I will need to change my Landis+Gry 5246C at some point, but I found its spec that says it has a 20 year certified life and mine was certified 04 2016.
I understand it doesn’t use the BBC4 Longwave switch signal, however, after a power cut the time is always reset +- a few minutes to GMT, which the Economy 10 switch times use even in the summer. I’m fortunate that my supplier offers me a decent rate for 10 hours (same as their Eco 7 low rate) spilt during the day which is great for storage heaters, Infrared panels and using power hungry appliances. They have also told me when the meter needs replacing it has to be smart and only Eco 7 or a smart rate.
My question is, if it just has its own RTC then what is resetting the time after a power cut?
… I thought it had an MSF receiver, npl.co.uk/msf-signal, used for clocks, watches, commercial and military kit to keep accurate time, which is not being turned off.
This is cheap enough to be used and when the meter was fitted I was told its clock is always a few minutes out to prevent power surges, like kettles during major TV football halftime. While I found the specification online there’s no mention of what clock is used - does anyone know?
All meters installed since 2006 are digital and fall into a band of metering called MID (specifically for residential and small business NOT 3 Phase or CT metering), these can be "in service tested" by the manufacturer and recertified without changing the meter and without testing the meter in your property.As an update I found that the UK ‘metering folk’ periodically test an example of each non-smart old type meter model ‘in the field’ and either keep to its certified date, or lengthen or shorten it depending on the tests - they the update the suppliers. According to my supplier, Octopus, when I mentioned mine was certified to 2026 they came back with its on their system as 2031! Obviously, as long as it still works. They did say that folk with electric heating, including storage heaters, can go on their rate for heat pumps which has 9 hours of cheaper rate. When they looked into it further they found it was the same rate as I get 10 hours cheaper. At least I know if I need to change to a smart meter I can almost get what I do now. They really do seem to be honest and fair, unlike my previous two suppliers years ago…
