There is no price it's meant to be free.When you get the price back, post it here and we can try to sense check it for you.
Low incomes and certain medical issues.Happy days, is this is the scheme for those who are on low incomes?
Either way post up the proposal of works, it’s always worth a sense check.
The main thing with a heat pump is to get the heat loss survey correct and setting up the controls properly once installed.
You can check their heat loss calculations using the heat punk website.
qualityIn the process of having an install in my renovation project. Floor (suspended timber), has been lifted and insulated. We have gone for radiators on a manifold system and a 5kw heat pump with unvented cylinder. Will drop some more details shortly.
Not sure I agree with your take above.
Higher water temperatures are just less efficient regardless of the source of heat and should be avoided if possible. The cost of slotting in a slightly larger radiator are lower than the running costs of going higher temperature.
There are also other benefits to lower temperatures such as having a more consistent temperature which is more comfortable. It is also safer for children and the elderly who may not realise their 70C radiator is scolding them. To reiterate, this applies to gas too.
Moving to heat pumps and away from fossil fueled boilers is a perfectly valid energy policy and is ultimately going to cut energy consumption by 2/3 and make us less reliant on expensive imported gas. How is that not an energy policy?
I’d presume they already have a wet system which was powered by the back boiler.
All of the cost associated with putting in a heat pump is all the labour with re-working the existing heating system, the heat pump itself is not actually that expensive. With the £7500 grant, you can get a heat pump retrofitted for as little as £500. If you are starting from scratch, the only real difference is the cost of the heat pump and a gas boiler as you should be designing it for low temperature anyway.
Combining insulation, solar and heat pump could significantly decrease your running costs if it’s installed correctly. This will in turn add a bit of value to the property if you own it.
There are some obvious synergies between solar and heat pumps. While you will not be producing enough energy to power your home and heating over winter, the excess you sell to the grid in the summer will pay for for some winter use. Between the end of March and October, all your space and water heating needs will probably be covered by the system assuming is of a decent size and not a token 4 panels.
Is this a council led initiative?
Our heatpump is an older model and its not silent by any means - but its cerainly quieter than my parents oil boilder that sounds like a trainee digeridoo player thanks to the vertical extension on the flueThis.
A boiler is pretty noisy and no one complains about having one in their house. A heat pump is outside!
What change is coming? I'd be keen to find out what planning regs might change, I'm looking at options tooYou can run your heating and hot water at different temperatures, 50C is more than fine for hot water and is more than achievable on a regular heat pump, you'll still be mixing down at 50C as its too hot bath/shower in. The only advantage of hotter hot water is you can store more energy in the same size cylinder, you'll be paying for it still.
Microbore might be an issue, it might not even with 8mm microbore. It depends on your heat loss and how much flow you need to get around the pipes. I've got 10mm microbore, its not an issue.
The units are more expensive to buy but they cost less to run and should last a long time, it should come out in the wash. Servicing is so, so and largely because there is little competition in the market, not that there is really anything to 'service' outside of cleaning the condenser - feels like a bit of a warranty racket to me. Once the warranty has expired, I'll not bother.
Efficiency is a function of your target flow temperature, how well your controls are set up and if the installer did the heat loss calculation properly. The issue is that difference between a bad gas install and a good one is 10-30% efficiency loss most people don't notice or care, a heat pump it could be 10-200% loss, it can go very wrong.
Heat pump placement can be problematic but the rules are being changed in a few weeks to be less problematic. We only really had 2 places ours could go, one of which was vetoed by Mrs Sk8. Neither were perfect and as its a retrofit, it means there is an external pipework run but it is hidden by the geometry of the house most of the time.
Basically to get shot of some of the placement constraints.What change is coming? I'd be keen to find out what planning regs might change, I'm looking at options too
My Daikin is directly under my lounge window (double glazed but total rubbish when it comes to heat retention and noise reflection) and you have to press your face up against it to hear it when it’s on.Our heatpump is an older model and its not silent by any means - but its cerainly quieter than my parents oil boilder that sounds like a trainee digeridoo player thanks to the vertical extension on the flue![]()
To be fair to ours, it would be that way too if it wasn't between our house and our neighbours house - the facing brick walls seem to pick up the exact frequency of the compressor at low load and throw it into our hallway window - its still not what I would call loud.My Daikin is directly under my lounge window (double glazed but total rubbish when it comes to heat retention and noise reflection) and you have to press your face up against it to hear it when it’s on.
How is that any different to a thermal store?They have basically inverted the cylinder. The hot water from the heat pump (or boiler) flows into the main body, not the coils.
And hot water on demand flows through the coils and is heated as used, just like a combi-boiler. No expansion vessel is needed, no legionnaires cycle needed as there is minimal water stored, and it's always flushed through the coils.
It will fit inside a standard kitchen cupboard under the worktop. There are a range of sizes available if you have a bit more space.
Here's what Heat Geek say;How is that any different to a thermal store?
Sounds like a small thermal store to me. The small size being the limiting factor which they are selling as a plus point.Here's what Heat Geek say;
"I don’t think thermal store is a good description for the ministore… . People are calling it a thermal store just because the DHW goes through the coil. A normal hot water cylinder is also a thermal store officially.. you heat it and store it until use.The ministore is more like a tube in tube heat exchanger. As it gets most of its energy from the heat pump recharging it rather than its stored reserves (like a combi with preheat switched on).If you have to categorise it I would say a tube in tube heat exchanger with built in buffer. Or a heat pump powered instantaneous water heater. But not a thermal store.Traditionally a thermal store is used to describe something that keeps the whole heating system (including rads) at hot water temperatures, so way less efficient for heat pumps."
So with that. You don't need a hot water tank? People with combi boilers can just do a swap?This is going to be a game-changer for people who don't have an airing cupboard, or they have one but it's too small, like what I was told from Octopus.
This Invention Will Change More Than 10,000,000 Homes!
This one is huge. We have invented something that will allow Heat Pumps to be installed in almost ANY home across the UK, whilst being more efficient than a ...www.youtube.com
More details on how it works here;
The Worlds SMALLEST Cylinder is here!
Introducing the Heat Geek Mini Store! In this video, Adam goes deep into the inner workings of the new Heat Geek Mini Store, a GAME CHANGER for the heating i...www.youtube.com
