I didnt realise the v2 was made for the AiO.
I'm on the fence whether to get a fractal terra but that silly "I'm sophisticated, look at me" wooden panel on the front puts me right off.
I'm a watercooling guy so my worries for the cases a bit different. I have a 1080mm external rad I use so I can have a tiny case.It's not exclusively AIO but the vertical mounted GPU really limits your CPU cooler options. They've also shifted a lot of the case internals downwards to accommodate a radiator at the top.
I really like the Terra and don't even mind the wood panel but I'd be weary of a CPU cooler fan being so close to the side of the case - in terms of noise / turbulence, mainly.
Any one have any success installing 2x 3.5 drives in this case? I have some storage to put on the network and this is the only PC i have with spare SATA connections. It would only be temporary whilst i get the data of the drives. Would it be safe to have them loose on the floor of the case for a few hours?
I was intrigued so i lookedI've got 3x 3.5" HDD's, 2x 2.5" SSD's and 2xNVME drives in mine...
Check the pictures linked above.
three HDD's is impressive, no GPU to achieve it, but very interesting build.
Where can I still buy v1?
Oh, that is great news! I'll be hunting for one then.There does seem to be a shortage of stock at the moment but one of the CoolerMaster reps on Reddit, confirmed that the V1 will still be sold and isn't being discontinued. May be a shortage currently because a lot of people thought the V1 was end of life and maybe bought up the available stock?
Or try to get that Jonsbo Z20, but that one is not yet possible to buy in UK, only via Aliexpress...
Oooh, contacting them nowThe Z20 is a nice alternative although I wish it had a solid side panel instead of a glass one.
If you contact Jonsbo they are usually pretty good and prompt at giving you an estimation for stock arrival into the UK. I had contacted them about the larger D31 before it came into proper UK availability and the estimate was pretty accurate.
I picked up a PC yesterday in a nr200p, it's got a 240 AIO side mounted, RTX 3080 in normal position. (I am changing this for a 7900 GRE though)
What is the *best* cooling setup/orientation for an NR200p with an AIO? it's a 240mm arctic cooler. I've seen people mod to top mount a 240 AIO.
I think it's currently setup as AIO as intake with side mount, then 2 fans on the top to exhaust, GPU in horizontal position.
thanks both!
