I dont think I have ever even played on mine besides from some quick testing - I really should spend more time with the systems... With the hinge, normally they go floppy because the plastic cracks, if i remember rightly there is a little "thing" that goes the other side of that metal ring that has a hard clip thing... yea I know terrible explanation but its that that gives the stiffness and the click into place that the hinge does...
I had a good look around last night and your difficulty might be finding replacement shell parts.. I couldn't really find anything for the OG 2ds system.
No worries mate. I scoured AliExpress in the end, have ordered a new screen and plexi. Have managed to find a black top hinge surround which will do, I'll see if I can glue the blue one but if not I have a fall back plan.
Hopefully it's just failing to initialise because of the screen. Would save busting out the hot air.
ive got a panasonic digital camera with a faulty display if you want something different to play with
thanks dude!
- If its ram... possibly fixable if its the IMC probably not... Don't know whats common on the 2080ti.. In the right hands it might be fixable im just not sure these are the right hands. I do need to get some GPU's on the bench as im frankily embarrassed how behind i am with stuff!
