Deleted User 298457
Deleted User 298457
You'll just take a pill in the futureThey are doing that in fields near me, a huge solar farm over several fields. All prime agricultural land.
i am torn on solar farms as well but am not a nimby. if they are absolutely needed then ok but I am not comfortable with doing that but at the same time not forcing solar on all new builds and car park covers and industrial roofs .There is tons of unused fields.
Looks like we found 4 of the nimby's on here.
Got no objections to roof tops being used, but the problem with that is they tend to be just used to power that building, not as a regional resource.
Dont have the option as I rent, This is the problem with the current method of people putting on houses as its just a personal use thing and does nothing for those who dont have that option. I get where you coming from, as I am sure people will say solar is something to be done on your own home.i am torn on solar farms as well but am not a nimby. if they are absolutely needed then ok but I am not comfortable with doing that but at the same time not forcing solar on all new builds and car park covers and industrial roofs .
also I think lake solar would be less upsetting to locals.
as for house owners using it... do you have solar ? (that isn't a dig) but 1) if it stops them drawing from the grid then it's still job done imo but 2) my system is tiny compared to a modern one (my panels are 320w modern ones may be 500w) . today my house used under 5kwh (will maybe be 9 by bed time) but I exported 23kwh. so for 6 months I still export a truck load during daylight.
Not by the same amount though, I thought you would have understood the meaning of my post, there is clearly an issue on dry windless days, the logical gap for that is (more) solar supply on the grid. But yeah didnt think of the export.430w is a modern mainstream panel, you can get higher but they are a lot more expensive, most people are fitting 430w as standard.
I've got 10kwp worth of panels on my roof but it is split east-west so performs more like a ~7kwp array which is south facing. Yesterday I did 57kwh and exported 49kwh to the grid, I've exported >1mwh to the grid this month alone, my bill is currently sat at -£115 after factoring the standing charge.
I don't agree its a personal use thing, it absolutely lowers bills for those who don't have solar.
True but those others didn’t spend thousands installing it so it’s understandable the direct benefit sits with me.Not by the same amount though, I thought you would have understood the meaning of my post,
Definitely, even if we are just putting panels on roof space, there is more than enough to power the entire country and then some when it’s sunny.there is clearly an issue on dry windless days, the logical gap for that is (more) solar supply on the grid. But yeah didnt think of the export.
And there are countless fields vanishing in the beauty spot countryside around here all prime agricultural land and all disappearing under concrete and tarmac of new housing. And thats permanent. Funny how politicians don't seem to have an issue with that.They are doing that in fields near me, a huge solar farm over several fields. All prime agricultural land.
indeed. image below from a few days ago from my modest system. (I picked that because charging my car didn't mess with the scale on that day).True but those others didn’t spend thousands installing it so it’s understandable the direct benefit sits with me.
Not really sure I agree with this take. The vast majorly of land used for solar farms and new housing/other development is not particularly productive.And there are countless fields vanishing in the beauty spot countryside around here all prime agricultural land and all disappearing under concrete and tarmac of new housing. And thats permanent. Funny how politicians don't seem to have an issue with that.
Building a solar farm is purely an investment for the eventual owners.i am torn on solar farms as well but am not a nimby. if they are absolutely needed then ok but I am not comfortable with doing that but at the same time not forcing solar on all new builds and car park covers and industrial roofs .
end of the day this is simplistic and we still need a reliable backbone but general terms solar can cover daytime (along with wind) with storage for the evening (and wind). in winter we get more wind (but solar still helps)
then for the 2 weeks max (generally) dunkelflaut SP! hopefully we have some storage but also we do for now need a backbone (maybe nuclear). - but tidal is also something we should make use of.
if we (and by we I mean government and energy companies) play our cards right imo this could be a lot of skilled jobs for our kids for the next 50 years or so (and then who knows maybe nuclear fusion will happen though am not holding my breath)
Did you have DNO approval to install that number?430w is a modern mainstream panel, you can get higher but they are a lot more expensive, most people are fitting 430w as standard.
If you’re installing 4kWp or less then it’s a ‘fit and inform’ process. If you want to install more than 4kWp then a pre-application with the local DNO is necessary.
The Harmonics caused by roof top solar is a major issue.Come to the solar thread in Home and Garden - we go through all the specifics and legislation needed to install large arrays.![]()
Looks like we found 4 of the nimby's on here.![]()
Who's going to pay for the many millions of £££ worth of capacitor banks to manage it?
Yes, all done by a proper solar installer, I’ve got an 8kw export limitation on my installation which my inverter capacity anyway.Did you have DNO approval to install that number?
That's the issue. Many installs are done on the cheap and not properly.you realise modern inverters filter the harmonics out right (not being provocative, just asking a question!!)? They have to be compliant to return to the grid - hence why they're tested when commissioning and why G9x applications have to be validated by an MCS installer. Filtering our the harmonics is not complicated electrical design - perhaps older inverters had issues, but I don't believe this is to be a major issue from my colleagues that work in this space.
Now if we're talking multi GWh of solar panels, sure but even then the way they system is designed will have an impact, and harmonic filters would be in place - you're right to mention it, but from my experience and conversations it's not a major issue at the moment. That said it could be if not done properly.
You then need additional filtering at connection zones.
