2 Jul 2024 at 20:19 #21 jigger jigger Soldato Joined 28 May 2007 Posts 19,828 ATIorNvidia said: As is current, voltage and thus power draw. That's why we have V/F curves and boost tables. Click to expand... You just said temperature wasn’t really a factor, but now it is?
2 Jul 2024 at 20:39 #22 Zeebedy Zeebedy Soldato OP Joined 28 Jan 2011 Posts 8,723 tbf, i found it extremely loud. i was lazy in not bothering with a AIO but now i decided to do it, i wont look back!
2 Jul 2024 at 20:47 #23 ATIorNvidia ATIorNvidia Associate Joined 10 Sep 2006 Posts 1,973 Location UK jigger said: You just said temperature wasn’t really a factor, but now it is? Click to expand... Not once did I say temperatures are not a factor. Do you always fish for arguments in the CPU/overclocking section?
2 Jul 2024 at 21:17 #24 jigger jigger Soldato Joined 28 May 2007 Posts 19,828 ATIorNvidia said: Not once did I say temperatures are not a factor. Do you always fish for arguments in the CPU/overclocking section? Click to expand... Not once but twice. ATIorNvidia said: Yep, people get really stressed out over the high numbers even though it does no harm to the chip. Click to expand... ATIorNvidia said: Not really. CPU's have V/F curves and boost tables which prevent exactly that from happening, assuming you aren't ignoring default spec Click to expand...
2 Jul 2024 at 21:55 #25 ATIorNvidia ATIorNvidia Associate Joined 10 Sep 2006 Posts 1,973 Location UK jigger said: Not once but twice. Click to expand... In response to you calling it a significant factor not once, but twice.
2 Jul 2024 at 22:24 #26 jigger jigger Soldato Joined 28 May 2007 Posts 19,828 ATIorNvidia said: In response to you calling it a significant factor not once, but twice. Click to expand... Nope. Troll harder.
2 Jul 2024 at 22:58 #27 ATIorNvidia ATIorNvidia Associate Joined 10 Sep 2006 Posts 1,973 Location UK jigger said: Nope. Troll harder. Click to expand... Pot calling the kettle black?
3 Jul 2024 at 01:00 #28 banja banja Soldato Joined 4 Aug 2006 Posts 2,609 I was considering upgrading to a 5800X3d, but research suggests I'd likely need to upgrade my cooler (Cooler Master Hyper 212 Black Edition) But the 5700X3d seems to offer only slightly lower performance, and if this thread is correct my cooler should be fine for that CPU. Last edited: 3 Jul 2024
3 Jul 2024 at 08:58 #29 jigger jigger Soldato Joined 28 May 2007 Posts 19,828 banja said: I was considering upgrading to a 5800X3d, but research suggests I'd likely need to upgrade my cooler (Cooler Master Hyper 212 Black Edition) But the 5700X3d seems to offer only slightly lower performance, and if this thread is correct my cooler should be fine for that CPU. Click to expand... Looks more capable than the wraith so it’s unlikely you’ll need to change.
