I have managed to get it stable at 1900IF / 3800 ram cl14
Had to use 1.52v to get there though - I have read that b-die are safe up to 1.55v, is it ok to run 24/7 at 1.52v?
System is very zippy so hope so.
I have the 3600mhz C14 kit and had to drop the speed down to 3466mhz to be able to use Gear 1 but that could be down to having a non k cpu. In benchmarks it is quite a bit faster faster than 3600mhz Gear 2 though.
Hmm... probably been about 2 years now I've had my 8 pack ram (which I run at XMP)
Last two evenings when turning PC on from cold it is failing to post and resetting the bios.
I had -15 CO on my cpu but thats been on for about 2 years as well.
I've since removed the CPU undervolt and will wait to see what happens tomorrow.
Could be that there is something developing with the ram.
Even though with the -15 CO on the CPU and the ram at XMP everything works perfectly. Can game happily for hours and have done for two years, its just cold boot suddenly seems to be an issue.
