Slap a K CPU into a W680 along with some ECC and call it a server: nobody ever got fired for buying Big Blue, right?
(The phone's autocorrect wanted to change big to buggy for some reason!)
Unless they need the E cores and/or overclocking, wouldn't they lowest Xeon be better?If your application requires high single thread performance it is a valid approach.
They get absolutely smashed by Ryzen (AMD's equivalent Epyc 4004) in multithreaded, so it is hard to know why anyone would buy these Xeons.Xeon 2488 is very similar to 14900K but has a lower TDP. Well and less cache but that might be due to no E cores.
14th gen (specifically 14900k, 14900KS) are a complete joke for gaming anyway. Not sure why any gaming datacentre's were buying these when Zen4X3D is available.
Even if the CPU's were stable, AMD is just so much more power efficient. With datacentre power being so important, I'd have thought it would be a huge incentive to swap to Zen4X3D. Imagine the power saving when considering thousands of these CPU's... Mind boggling.
I think Arrow Lake and future Intel CPU's will be clocked much more conservatively.
Sounds like a politicianOnly Intel calamity after Intel calamity for an extended period is going to change that mindset, not least because people who think of themselves as expert hate being wrong, it makes them feel like fools when what they want to feel is expert, so they still kid themselves its worse on the other side, some how.
Only when their reputation is questioned for their play it safe with Intel mentality is questioned will they turn their thinking up side down and pretend that not going Intel is the clever, the smart expert's thinking because now you've been stupid and people are beginning to see it, you've been found out, you don't actually know anything at all.
Sounds like a politician![]()
Yes, and it is, its all politics....![]()
Faults like this can kill a companys reputation forever as none want a dead cpu inside like intelPersonally, I don't care whether the fault is with the cache, voltage, or whatever. It doesn't work as intended. It should be withdrawn asap.
for all the companies that were 'steam rolled' and bankrupted. for all the attemps to crush AMD. for all of their customers who were / are being ripped off -Faults like this can kill a companys reputation forever as none want a dead cpu inside like intel
Yes as any potential system issue could be a CPU issue now the longer this goes on and it could snowball to the point where people will switch to a competitor to fix the issue.Faults like this can kill a companys reputation forever as none want a dead cpu inside like intel
I remember those days -Not just for this reason alone, but I have tended to be influenced to remain with an Intel based CPU platform because it has, for me, just worked and done so reasonably well, if not great. Going forward, if that thought of stability becomes more questionable than it has of late I am considering an AMD based platform that for me is quite a leap. Not necessarily because an AMD platform has typically been "bad" but familiarity and comfort has typically meant an Intel based PC just works and does so consistently and is always stable.
So far, no reason for this to change, the total stability has been there with my 14700k and a Z690 board. As it was with the 12700k and the 9900k before it.
Brand confidence, maybe more reflective of the 13900 / 14900k CPU's, is starting to be more questionable, by myself.
Time, along with Intel's response and action will be interesting to note. AS will the up and coming CPU's, from both Intel and, maybe more interesting, AMD.
Thing is even before the instability, the peak power would have made me avoid Intel. Even when they won by a small margin, the power consumption was just crazy.
At least previous high power Intel platforms were HEDT and not mainstream - with the expectations that HEDT and low end workstation stuff is just better engineered.
