Be interesting to get a map location to see how far he'd walked/how far from any paths he was found.
thats where his phone last pinged , Masca is to SE ,
You tend to need to get really low and have a look from all angles in body searches (even in a lot of live searches)rip
Like for Dr Mosely, optics on search teams drones, are they really poor ?, versus ubiquitous reaper/military equipment with some AI processing.
or, in this case was he found in a completely vegetated area with no possibility to see from above.
Too late now, no?It doesn’t look far away from help.
I’d imagine his brain wasn’t working to full capacity after a night on the booze and disco biscuits.It doesn't look like he'd even set off in the right direction.
Too late now, no?
It’s just hard to imagine how he failed to make it a couple of km at the time.
Middle of the night, pitch black, drunk, tired. Not really. It’s also very easy to panic and lose your bearings, especially once your phone dies. There are plenty of places on those islands that aren’t lit at all.
Bit defeatist.Too late now, no?
Think the lady that told him waht time the bus was coming and last saw him said he was heading northIt doesn't look like he'd even set off in the right direction.
Have you ever tried walking an unfamiliar area at night with no guide and over rough ground? It's not hard to imagine at all.It’s just hard to imagine how he failed to make it a couple of km at the time.
People have died less than 100 meters from help in the past because once you're off the route at night in the dark it is very easy to get disorientated and head in the wrong direction or injure yourself badly enough you can't carry on and that's if you're fully sober.
IIRC the advice for anyone who ever gets lost is basically stay on the road*, not wander off into the wilderness, which it sounds like is what he was trying to do.
*Or in remote areas with no roads, the river/streams as humans invariable build along almost any watercourse eventually.
military capability probably as much for living humans and inanimate objects but their drones seem impressive (2mm?)Drones can be very good for finding live humans, especially at night, but even thermal imaging sensors still require LOS to the person and basically the higher you are the wider the area you might be able to see, but also the higher the chance you'll miss something if there is any variation in the ground level or vegetation.
The last call to his friend before his phone died was at 9am.
Bit defeatist.
I dunno man, just takes one fall to conk yourself out and be in serious trouble.Must have been off his face then if he managed that in the light.
