Man of Honour
- 21 Nov 2004
Love it. I’d totally drop something into it though shorting the whole thing out.
Yep! - For the black version are you going WC, or gonna stick with the air cooler? (What card is it? I know you showed the ProArt, but 4080/4090 etc)
nice board mate. Will be interesting to see what speed you get with the ramAsrock as promised sent over the board i needed for the Black Version to pair with the Memory kit for this build. Now whether i can hit 8000mts using the xmp profile will highly depend on the cpu i test it with, i have my new trusty 13700K which seems to have a pretty good IMC so here's hoping.
The board is pretty perfect for the build, all black, no rgb, no fuss. Pics of the actual board coming later tonight
I've always liked open cases and considered a build myself, but the dust, cat hair and little cat noses would disagree!
, thanks man.
I was about to say dust isn't so bad, infact it's less than having an enclosed case as there's minimal fans blowing dust onto your components but the cats would definitely disagree![]()
I was surprised to find this, when I built my first PC in what I would call an open case. It was an Antec Skeleton and the 200mm fan on the top kept the dust off everything. I still have it in the loft!
But yes, kitty cats are not going to love you for having open fans on external surfaces like this build! Ouch!
P.S. yes to the vertical mount.![]()
. I remember wanting one but not being able to afford it at the time.who's done that?i have a custom waterblock being made for our Asus ProArt 4070 Ti coming
who's done that?
one for the address book. I've already done the design work for a Quadro P400 block, but always good to have references.
The P400 block is part of a bigger run of stuff I'm going to get Alex to quote on, but the more options the better before I decide I can't afford any of it and Asteria 3 stays in Fusion 360 like she's done for the past 3 yearsDefinitely one to reach out to if you want your design to come to life. I've seen his work from another creator and it's pretty good, especially for the price.
The P400 block is part of a bigger run of stuff I'm going to get Alex to quote on, but the more options the better before I decide I can't afford any of it and Asteria 3 stays in Fusion 360 like she's done for the past 3 years![]()
