What welder did you go for? I have rusty rear arches on my 9-3 and tempted to repair with the pattern arches available as bit of a project.I welded the entire inner arches of my Saab 9-5 for £200 and that included the purchase price of a welder.
Both sides and both still solid 4 years on.
presumably you can tell if it were coolant. I used newspapers and old towels beneath the carpet for a while, while mine dryed out,and coolant and prey it's not the matrix.
I looked at the GTR in detail, its on my list. I have a good friend though who runs a JDM garage and after a long chat with him, I decided against it. Not sure Id appreciate some of the risk/bills.
I loved the ISF, but think Ive discounted it now. The RCF was cheap at £25k, any more expensive and Id discount it I think. My current focus is the BMW i8 - made an offer last night on a good approved used but as usual it came down to £500 either way, which is nothing really, but I just like to at leas feel I got some kind of good deal![]()
So satisfying! I just did this on mine when the car got diagnosed with fatal rust. The replacement fob is a mass of glue and cracksNew remote fob. Spent months mashing the buttons to get the car locked or unlocked and then raised the funds to spend £10 on a new one and quickly code it and swap the transponder chip across. Just needs a gently touch of a butterfly to open now ( or feels like it anyway!)
Mine had rust along the sills which would likely fail the MOT next year but was worth (to me anyway) forking out for them to be repaired / welded. It's a good runner and not worth much more than scrap I don't think.So satisfying! I just did this on mine when the car got diagnosed with fatal rust. The replacement fob is a mass of glue and cracks![]()
220 miles, door to door so including a diversion to the hotel via Asda and about ten miles through town and the 50mph roadworks sections on the M25 southern section and the same on the M3.10 MPG![]()
