We'll remind you of this after your first Over/Under workout...looking forward to it to be honest!
After following a calibration instructions for the turbo, I'd start with either the standard ramp test, or even ramp test lite if you are pretty sure your 5min power is under ~225W. Pick a route that will take ~20mins if you want to do approx one lap during the test, so ~8Km+ on a flat course, or something longer/hillier that you might need to complete to get the badge bonus after the test is complete.anything recommended to start with ? my zwift year code went *somewhere* because I day-dreamed and typed the wrong email in so now waiting for support to respond(30hrs and counting) but looking at the workouts etc, recall there being a GCN workout plan but that is gone now.
I think they made the Everest challenge default recently.Do you still need to join one of the Zwift challenges manually? If you do, join the Everest challenge when you start as you need something like 50,000m climbing to unlock the Tron bike.
Well done
First attempt, it’s tough.. and I’m sweating way more than I expected. May have to get ac blowing my way.
Good post. That shopping list is gold. They should get rid of the Tron bike imo. When you look at the numbers very few bikes will beat it. It looks dumb too.After following a calibration instructions for the turbo, I'd start with either the standard ramp test, or even ramp test lite if you are pretty sure your 5min power is under ~225W. Pick a route that will take ~20mins if you want to do approx one lap during the test, so ~8Km+ on a flat course, or something longer/hillier that you might need to complete to get the badge bonus after the test is complete.
To gain XP and level up quickly for relatively decent racing frames and wheels, look for late join options, mostly on group rides and workouts. Late join works until 30mins after the pen started, so can give you easy badges on sub 15Km routes, or help you on way to completing longer courses.
For racing especially, grab the Shimano 50 wheels that are ~34,600 drops.
Frame wise, the Parlee ESX is ok for a starter at ~150,000, but the sooner you can buy the Bridgestone Anchor 9 (as short term benefit); the Scott Addict (great all-rounder for ~660,000); or the new Canyon Aeroad 2024 for ~1.1 million drops the better.
If you do a load of late join route badges, you can roughly buy one frame upgrade and the Shimano 50 wheels, to still have enough drops to buy the Addict for 660,000 at level 17 (50,000 drops award per level-up).
But you will often be disadvantaged to some degree in races until you reach approx level 25+, those with the Tron or those level 39+ with the DT Swiss Disc wheels have a major advantage on many routes... I keep saying races should put all on same virtual equipment for fairness.
Zwift Shopping Guide: What To Buy from the Drop Shop at Each Level
Know where to spend those hard-earned Drops!zwiftinsider.com
The robo pacers are worth a try if you want to get some steady miles in and get a feel for riding in a group. They can be quite chatty and there's a drops multiplier that ramps up to 2.5x. If you find yourself in the wrong group it's easy to teleport to a faster or slower one.anything recommended to start with ?
This ZI page has a nice scatter chart https://zwiftinsider.com/tron-vs-top-performers/ - the Tron is a great all-rounder but not the best for flat or climbing routes.They should get rid of the Tron bike imo. When you look at the numbers very few bikes will beat it. It looks dumb too.
seem to be sweating more than I do on road for sure but not that much, I got a cheap £5.99 car boot floor mat from lidl on Monday so that is sitting under the bike to catch anything, it's in my mancave so the whole place gets quite cool just need to point the AC towards me and get some cool air blowing in that direction. Only other thing I'd like to do is raise the TV a little bit so it's higher up(20cm or so)Well done. As the quote goes, "it never gets easier, you just go faster"
If you sweat like I do you'll end up with a big waterproof floor mat, several towels and a stupidly powerful fan.
just to add, great info! much appreciated. I need to figure out the whole system..After following a calibration instructions for the turbo, I'd start with either the standard ramp test, or even ramp test lite if you are pretty sure your 5min power is under ~225W. Pick a route that will take ~20mins if you want to do approx one lap during the test, so ~8Km+ on a flat course, or something longer/hillier that you might need to complete to get the badge bonus after the test is complete.
Yep, seen that. Looks like the new Aeroad is the best all round on there to me, depending on wheel set up. Although very few courses are like the Alpe or Tempus. I still feel an aero set up is going to be better for most people but it would depend on the rider. I haven't raced for a while but I'm top end of Cat C, big power outputs but higher than average bodyweight so in my mind anything with over 500m elevation I'd be best with more of a climbing set up as keeping up with the front pack on the flats isn't an issue for me.This ZI page has a nice scatter chart https://zwiftinsider.com/tron-vs-top-performers/ - the Tron is a great all-rounder but not the best for flat or climbing routes.
Can you imagine the uproar if Zwift got rid of it?
You take that back! The tron bike is excellent and shows you are clearly a chad.
presume run an FTP test on zwift, where does the power figure go then?
The figure given by the ramp test should have automatically been placed in your settings.as far as calibration goes, I did the "spindown" on wahoo app, I keep seeing people talk about getting you estimated FTP right. What is the correct way to do it? presume run an FTP test on zwift, where does the power figure go then?
I left all the other wahoo settings as is, so power smoothing disabled etc. Anything I should change/enable?
edit, did the ramp ftp test, that hurt.
average of 180ish so if I can get to 200 or so by end of year I'd be happy. I initially estimated mine to be around 140 since the last time I cycled properly was in 2017. That's around 2.1w/kg at my current weight of 88/90(fluctuates quite a bit)
