What? Don't tell me you're gaming? Pfft.I don't run 7-Zip for 4 hours every Friday night, but nobody seems to have a problem with those tests?
But they do 4k tests and it's just a wall of bars all exactly the same length. You understand the thing holding you back at 4k is the GPU. There's nothing more reviewers can do about that.
its a bit like the Idle temps which is most of the time you have it turned on vs the 2-4 hours of gaming a nightI don't run 7-Zip for 4 hours every Friday night, but nobody seems to have a problem with those tests?
Ah so it's an Intel Vs AMD issue rather than CPU performance, gotcha!It seems to me that the reviewers are hyping everyone up over the 9800X3D and destroying the intel, when truth is that many people wouldn't notice the difference between the two,
But seriously - what info would you get from a 2k/4k test that you wouldn't get from 1080p testing? The same, but reduced margins because you become more GPU limited. They test 1080p because the GPU bottleneck is removed and you are testing purely CPU performance. There is no instance where another CPU would perform better at 4k than it does at 1080p. The tests were exactly the same when Intel was thumping AMD.But they can. They could, for example, run a series of games tests at 2K and 4K for a range of older CPU's, so that people can see what they would get in an upgrade.
I always remember upgrading from a 4th gen to an 8th gen. It made no difference to the highest FPS, but it made a very significant difference to the lows and to the smoothness of the game. This is the sort of information people want to know.
It's difficult for the reviewers, but I just think that presenting the information they do is kinda pointless. It's like saying - look how well this racecar does on a racetrack. It's useless information for someone who lives in a city.
It seems to me that the reviewers are hyping everyone up over the 9800X3D and destroying the intel, when truth is that many people wouldn't notice the difference between the two, because they don't game at 1080P. Well, I suppose that's not quite true, but perhaps people shouldn't be as hyped as they are. The tests are misleading people.
I don't get this because reviewers do show 4k graphs of older CPUs. You do get to the point where they can't be constantly updated because every time a CPU comes out there will also be multiple updates to Windows and games so to be fair you'd need to fully retest all CPUs to be accurate and reviewers simply do not have the time to spend a day or so per CPU. The thing is, you know how your own CPU performs so you can get a rough idea of how a newer one will perform based on the numbers provided by reviewers.But they can. They could, for example, run a series of games tests at 2K and 4K for a range of older CPU's, so that people can see what they would get in an upgrade.
They simply cannot cater to every single scenario or hardware combination so that's down to you to fill in the gaps.
If a CPU review doesn't have the info you want find one that does. There's no shortage of CPU reviewers. And things like shader compilation times is a niche within a niche.But a lot of CPU reviews don't give you enough information to fill in the gaps from... i.e. the power use while gaming from 1080p often does not represent the power use when gaming at 4K which can be quite a bit different and even counter-intuitive sometimes, sure that might change again down the road with future GPUs.
Another aspect not really covered and sure it isn't something you spend a lot of time doing, but I setup a bunch of systems awhile back installing games and software, etc. and there was a big difference between some otherwise fairly similar CPUs and sure you don't spend a lot of time doing those tasks but it is still not a negligible factor. Would be interesting to see the results of benchmarking the shader compilation on something like Hogwarts Legacy albeit the shader compilation in that game is a bit of an aberration and something I'm sure they could fix.
Maybe what you really want is bespoke CPU reviews where you can pay someone to test exactly what you want in the exact way you want it done.
You're asking too much from a launch CPU review. Maybe you'll get details like that further down the road after a specialist website/youtube channel does a deep dive but that's of little interest to the majority of people who just want to know is it x% faster than this other CPU.But it is pretty relevant information - shader compilation performance can make a difference also to frame times in some games and hence the feel of the game vs the on paper performance numbers (which isn't something itself which can easily be measured due to also a subjective component as some people are more sensitive to it than others).
A lot of CPU benchmarks are quite limited in what they really tell you - which is why I spend quite a bit of time playing about with stuff myself, usually get slated for mentioning stuff then more often than not get proved correct in the long run when someone finally does a proper deep dive :s
It's like arguing with flat earthers!
The people that had the most questions and wanted native 2k/4k testing are from 9800X3D reviews and videos...I'm happy to be corrected as reviewer 1080p testing methods was not a concern when Arrowlake reviewed 3-4 weeks ago.Ah the age old resolution debate. Bang on clock work, every CPU launch with the team on the losing side wanting 4k. I would be more interested in 4k results with these CPUs once 5090 has been released....
and yes I play nothing but 4k with super marginal differences . Would be nice to see a few 4k tests . Not everyone on the forum is a fanboy
Team on loosing side? I don’t care what cpu I get. As long as the gains are goodand yes I play nothing but 4k with super marginal differences . Would be nice to see a few 4k tests . Not everyone on the forum is a fanboy
