Would a Noctua NH-U12S with dual fans be enough to cool the 9800x3d? Without overclocking. It works fine for my 5800x3d. Want to stay air and perhaps safe myself some money on the upgrade lol
Easily. X3D chips aren’t hard to cool.
Currently have my 9800x3d with 2x scalar, +200mhz, -35 CO. Hitting 24300 or so in Cinebench R23. All core maxing out under full load around 72C and a vcore of 1.2v.
Is that a decent chip or pretty much what most people are seeing?
Seems ok, I think many people can dial in -40 curve, +200 boost, boot and play a few hours of games.Currently have my 9800x3d with 2x scalar, +200mhz, -35 CO. Hitting 24300 or so in Cinebench R23. All core maxing out under full load around 72C and a vcore of 1.2v.
What is not apparent though is when clock stretching is happening on this stepping we have, or where this is actually stable considering almost everyone is using a RAM OC (remember, every expo profile is an overclock)
Read lots of immediate success going straight to undervolts with max boost override, read almost as much stress test failures doing so.
And as a couple of people have rightly pointed out, we're not getting the best bins. AMD have always binned their best CCD complexes for the preferential CCD on the 16 core SKU.
When did they come back online for pre order? I presume this is the wave for Jan25?Managed to pre-order today, along with a bunch of other things
Now to wait on the new generation of GPUs![]()
I hear that, spent most of this week tuning and doing stress runs. And that's after picking kit for ezmode, not performance.I got this chip on Wednesday, and I literally haven’t been able to do a single solitary moment of gaming yet. Work, coupled with my brain not allowing me to ‘Expo and go’ can be annoying at times lol.
I can never get a new component without obsessing over squeezing out every drop possible.
As much as I love overclocking (especially RAM) I can’t wait to be done with it so I can have my system back
Here's how it goes
.oO
Ryzen IMC is still a lottery
But boards and BIOS have matured
Still, life's too short, 6000/30 is almost a gimme
May as well buy 64G @ these timings
Oh, 6200 was ezmode as well, what's in the tank?
Well, we've booted CL28, it's only a few tweaks from stable right?
Glad I only spent 6 hours getting CL28 "stable", tweaking 128G DDR4 was much worse (it wasn't)
CL28 cleared X test after X hours, time to pwn the noobs!
Was that packet burst or IMC error correction that killed me?
Oh, this higher intensity shorter test throws errors.
Let's relax the main timing and focus on the IMC
Well, that was only 2 days of testing, not bad for this ezmode kit right? right...?
Let's bench the pwn the noobs game again, yep still zero CPU bottleneck but at least my ego knows it _must_ be packet burst that gets me killed
Now I've marginally OC'd my ram OC, I can tune my CPU, nothing better than knowing my zero CPU bottleneck will be even more zero, winning!
Sad or best part of this is I've enjoyed pointlessly tweaking ram more than playing the current crop of games
¯\_(ツ)_/¯
So this is where things seem to be given on faith. And I'm starting to suspect that some of this faith is given on nothing more than word of mouth.If it passes about 10,000% coverage in Karhu (Karhu claim 6400% shows up over 99% of errors), it’s almost certainly ready to go.
CPU is the very easy part in comparison. Set an aggressive undervolt/curve and just test in OCCT for one hour. If it passes that, it’s probably most of the way there. Small Linpack/YCruncher and play some games to confirm. If it’s not stable? Very easy to rectify. Just back off and repeat. CPU overclocking/undervolting is easy peasy. It’s RAM overclocking that’s the hard part.
RAM overclock should always been done and nailed in first.
For example Karhu suggests that my CL28 is stable after an 8 hour run.
But then TM5 fails the same timings within something like 15-20 mins
I think it's not fair to say y-cruncher is just a short cursory test. The all test run defaults will use all instruction sets available and with as much ram as it can use.
So what's going on here? I don't know that the source is available for these two utils (Karhu/TM5) so programmer error could be a factor in one or both of them.
I should also point out that one of the popular usages of TM5 is with a custom profile that's supposed to show errors "early". I find that somewhat unconvincing.
Though I've not yet examined the profile and the methodology it configures, I'm certainly curious why a mem testing tool would not be at its most effective without a custom profile.
There was a glitch with the OCUK website where for a period of time you could pre order the 9800X3D again but was sorted out so not possible anymoreWhen did they come back online for pre order? I presume this is the wave for Jan25?
yes i use a u12a and it cools it very wellWould a Noctua NH-U12S with dual fans be enough to cool the 9800x3d? Without overclocking. It works fine for my 5800x3d. Want to stay air and perhaps safe myself some money on the upgrade lol
