Not bad. But still £31.79![]()
Worth every penny. Even better if you have gamepass at the moment.
£24.60, and without a pre-order.
They gifted me the discount due to previous purchases. Just need to use it up during their Black Friday sales.
I’ve got it on GP anyway but won’t have GP indefinitely so will play it for a bit and make my mind up. If it’s great I’ll probably buy it as I can’t go wrong for under £25 on a new release. Will be a bummer downloading it again over my peasant broadband though!
Guns wear down way too fast.
I read on reddit someone claiming it's only 200 bullets from 100> to junk that jams every few shots.
A better way would just be letting you clean your own weapon... the money sink sucks, I'd rather have a minigame or something
I did one early mission at the poppy field, one choice was to get a gun as reward... so I get a named gun but it's 0 durability and needs over 8k to repair it
someone said there's a mission where you need 40k for some suit too, it's a crazy amount of money when durability is hammering your wallet, or you only use crappy found guns and dispose of them all the time.
but then what's the point of having special named versions of guns if you can't use them, some of them were meant to be rewards for delux/ultimate edition owners too.
what are you meant to do stick them in your personal stash and look at them once a day?
It's also likely somewhat due to the transition to an open world and it no longer being "sectioned". The computing power required to simulate the entire map at all once I can imagine is heavy.
That's not how open world games work and anything outside of the players sphere of influence can broken down to it's most basic form anyway.The computing power required to simulate the entire map at all once I can imagine is heavy.
5 hours in. Made it to the garbage. Got 30K coupons![]()
Sounds like the garbage starts right at the beginning.
Skill issueOK I'm done playing until they make it so the AI can't shoot through thick concrete walls![]()
I literally just stood behind a big wall and watched the bullets come through and hit me, tried again and the same problem. Can't believe they thought this was a good idea.Skill issue
Hopefully just a local issue to that area and not the whole gameI literally just stood behind a big wall and watched the bullets come through and hit me, tried again and the same problem. Can't believe they thought this was a good idea.
I've had that. Though to be honest my play style is to try and stealth everything. If they're already shooting at me, chances are that I'll die.
The lod issues on the trees and vegetation trigger me massively.
I noticed that yesterday when playing. :/OK I'm done playing until they make it so the AI can't shoot through thick concrete walls![]()
