Tbh that would make more sense. A 13600K is a beast especially when finely tuned. Either way, you'll never see close to double the performance gains going to the 9800X3D from it, but GPU on the other hand, almost trivial to do.Must resist upgrading from a 13600k to a 9800x3d... think I've decided not to!
Whether or not I can resist the upgrade from my 7900xtx to the 5000 series.. that's another question![]()
Started testing memory 6600c28
Back in stock for £500![]()
Dont think I would bother 6000/7000 series maybe not much out there to streach a 7900xtx as it isMust resist upgrading from a 13600k to a 9800x3d... think I've decided not to!
don't read that thread anymore but it's good to know thanks.Gibbo explained the other day why so it shouldn't come as a surprise:
AMD 9800X3D ETA OFFICIAL THREAD
So I rang overclockers about my 14:03 order. Turns out they didn’t get the payment until the next day from paypal :( looks like it’ll be late december for me. That's annoying but as Gibbo said though the quickest payment method is debit card. I normally use PayPal but after hearing this i'll be...forums.overclockers.co.uk
Just read through it there, very fair points from OC side so cant complainGibbo explained the other day why so it shouldn't come as a surprise:
what are your cpu over clock settings? I'm getting 250 fps but have 3090. At 1080p low I thought it would not use the gpu as much but i see it at 98% usage.
did you set cinebench to high priority in task manager details, that seems to bump it up a bit.5.4Ghz, -40, peaks at 1.23v core, 83c
You only need to look at the 7800X3D to see that this is the case. Cache placement has no bearing.Will the 9900X3D and 9950X3D be performing worse at gaming than the 9800X3D due to the nature of the chip design and Cache placement?
That’s expected as scalar allows the CPU to use a bit more voltage for an extended period of time. More voltage, lower clock speeds. More negative curve optimiser, less voltage higher clock speed and score.So this is with PBO enabled +200mhz -30 curve x10 scaler, ram has had it's timings tuned.
I just ran again with x1 scaler and got 10 pts more so there's no difference for cinebench
Exactly.for gamers, there is no point at looking at anything apart from the 9800X3D?
Yup, it's the best gaming chip.If that's the case for gamers, there is no point at looking at anything apart from the 9800X3D?
