We all know the Haribo was the most important part to arrive. Cannot build without it.The last ‘components’ have arrived ready for the build at the weekend![]()
The Haribo is there to distract the kids so you can build the PCWe all know the Haribo was the most important part to arrive. Cannot build without it.![]()
but does it workThe Haribo is there to distract the kids so you can build the PC
Completely agree! (will be rebuilding next week and will just be UV lighting with reactive fluid - as long as I can figure out how to fix/disable the RGB on my motherboard... no rainbow pukeGet these filthy RGB fans out of my thread![]()
probably not the best choice aesthetically but it was the most readily available CL28 6000 kit at the time of purchase:
You've put the fan nipples the wrong w
For fans "disable" is easy, just unplug them. For motherboard lights, black paint or duck tape can work at worst! Latest Windows 11 has Dynamic Lighting under Personalisation and that supports some controllers. Found out when my CPU cooler (run off Gigabyte mobo header) changed from unicorn mode to Windows blue during setup. Doesn't seem to spot the RGB logo on my Asus card though.as long as I can figure out how to fix/disable the RGB on my motherboard... no rainbow puke![]()
Yup, need there. Had to do mine again once I'd got the CPU in as Gigabyte had released a newer one and it appeared the version I'd installed had been made to have never happened.Oh god oh god oh god…
I was going to say it shouldn't be giving you grief. Mines running (for now!) on the cheapest Phanteks cooler that OCUK had in and it's doing quite well to be fair to it.Oops, I forgot to update this thread as I was having a mare with the CPU overheating. I'll get into what happened below
Let us know what temps you have on CPU etc.
I'm on 900 v2, always had noctua fans and will be getting one u have for 9800x3d build too.
Nice, thank you, and what about gaming?Hey there - with a -35 curve optimiser offset... and +200 mhz CPU boost override, I'm getting CPU temps of 51 browsing the web with chrome, as low as 43 degrees when fully idle.
Might be a silly question but have you set a frame rate limit in Nvidia Control Panel? They will often whine if they're pushing 500fps or something daft when you get to a menu if something non-taxing. Brand new 4080 Super did the same but it's not done it since I slapped an FPS limit in to match my screen's max refresh rate - no point in it ever rendering more frames than can be displayed!There is still a little bit of coil whine when maxed out so I've ordered some superglue glue and may try attacking the coil caps with it.
