Best value.
It is, it really is!
Best value.
Best value.
Good work. Was there absolutely no way at all to switch off that LED through software? I'm not thinking Zotac software just regular motherboard software. That does work per card though, so I was able to switch off the light on my 3080FE using Mystic Light whereas I can't with this 4080 super FE using the same software.More from camp Zotac 4070 Ti Super Solid
Took the shroud off the card and found the offending connector for the stupidly bright light on the spine of the card that can't be turned off. As noted before it piggybacks power from the 3rd fan. Just pulling that apart solved the issue AND got me 3w back according to the Nvidia apps statistics from 17w desktop idle to 14w. Winning. Photos in a spoiler for anyone who wants to see.
It's more like 15-20% more performance,and even more in 4k,ray tracing and path tracingVram is a concern but I went with the 4070s as I want the option of ray tracing and amd can't provide that for me. I don't plan on moving to 4k res so I'm hoping I'll be ok at 1440p. Feels ******* awful worrying about a new gpu's vram before even getting it but the price jump to the 4070 ti super is ridiculous considering it only has 5-10% gains. Yes it has the vram headroom but I'd need the vram headroom and huge jumps in performance to justify that mental price.
Do you think that'd work with this 4080 Super FE? Does it not clash with Afterburner?Should have just used EVGA Precision XI, that's what I use for the 4090FE to dim the front LED.
Yep still not enough to justify the 300+ quid extra they retail at for me. Will still be turning down settings in 2-3 years time with the ti super. Bit of a kick in the teeth after paying nearly a grand for the thing. But maybe that's just me.It's more like 15-20% more performance,and even more in 4k,ray tracing and path tracing
Just wait then for 50 series and perhaps some discounts on last gen?Yep still not enough to justify the 300+ quid extra they retail at for me. Will still be turning down settings in 2-3 years time with the ti super. Bit of a kick in the teeth after paying nearly a grand for the thing. But maybe that's just me.
I don't believe so as it shares the same 4 pin header as the fan, but only uses 2 wires. The fan needs all 4 so you'd not be able to turn off the light or control it as there is no signal wire, just live and neutral. The zotac software has a button for the lighting section of the app but you click it and it does absolutely nothing. I'm guessing because this isn't on a lighting header with a controller and is instead just permanent live when the board is hot.Good work. Was there absolutely no way at all to switch off that LED through software? I'm not thinking Zotac software just regular motherboard software. That does work per card though, so I was able to switch off the light on my 3080FE using Mystic Light whereas I can't with this 4080 super FE using the same software.
Just curious really because it doesn't matter in your case, you've found a solution and probably a better one than just doing through software.
To be fair I didn't try anything other than the Zotac software but as I say above, I don't believe it would have made any difference.Should have just used EVGA Precision XI, that's what I use for the 4090FE to dim the front LED.
Do these even really happen any more?
Used to, in the long past. Now the new gen launch at a higher price and the old gen just get run out at whatever price they're at.
Yes.
