Deleted User 298457
Deleted User 298457
Final check on the above chaps --- is it worth £600 without the half rack?
Could you tell me what bench may be a better idea? I think I had recommendation earlier in the thread for a Mirafit one, but if I am getting the weights elsewhere I can open up to other benches.yea it’s not a massive saving. Especially when you consider adjustable will go up to 32kg. Also the bench in the ad is not good.
Mega thank you.Something like this:
GM3 Fully Adjustable Flat | Incline | Decline FID Weight Bench - Gunme – Gym Master - Gym Equipment
Our fully adjustable weight bench, is able to give you flat, incline and decline surfaces so you can complete all your exercises, with non-slip cushionswww.gymmaster.co.uk
Basically the same as the Mirafit M350, but £100 cheaper.
How do you all go about getting rust of your bars / dumbells?
I've been accumulating rust for a while and kept being lazy about acting on it. I bought a Nylon brush from Rogue after I saw it recommended but the rust is deep and while its taken off some of the surface layer there is much more ingrained rust to go.
If I go for a wire brush am I going to completely knacker things?
This looks ideal for incline DBs. Have you used it? - is it well put together?Something like this:
They look pretty good, would be interested in a update when you've had them while.
You need the zwift companion app and that can connect devices, it acts as a bluetooth bridge, not sure about ant+ as ive only ever used it for the bluetooth element. I have my HRM and Zwift controllers connected through the app and trainer via direct connect, but before that it was done via wifi, but my trainer is a kicker v6 so that made that viable.Has anyone had any success connecting Moofit cadence and speed sensors to windows? Just wondering if I'm missing something as I can't pair them at all.
It mentions ANT+ as well as Bluetooth. I reckon my phone may have picked them up but can't confirm (got to like 5 degrees in the gym lol). Zwift also reckoned it could connect to phone as some kind of Ant+ relay maybe?
Edit: upgraded to a new BT adaptor; works a treat. I also bought an ANT+ adaptor at the same time just in case. Both were found immediately in Zwift. Seems to work good! Not sure if this needs calibrating as it's reporting 18mph and I wasn't even moving, but I guess that could be a quirk of the game. It'd be good to see real time data from the adaptors outside of what the game is messing with.
(PC case is hilariously oversized but I love it, lol - early 2000's nostalgia baby. A case not at all intended to be a pirates wet dream given it holds like 6 burners).
Edit2: @Martynt74 any thoughts on how I've put the cadence/speed sensor? I think initially we didn't think the speed sensor was possible. And is Zwift correct in those numbers it is seeing/does it wildly over correct to account for pausing for a second?
This may not be as cheap as the GM3 or Mirafit, but it's on offer and might last longer?Could you tell me what bench may be a better idea? I think I had recommendation earlier in the thread for a Mirafit one, but if I am getting the weights elsewhere I can open up to other benches.
I've told the chap I'll do £500 but not 600. He'll probably tell me to p-off given I offered 575 earlier in the week, and its listed for £800 (incl the rack admittedly).
So I plugged in a new fangled BT 5.3 USB (TP Link) and an ANT+ (no brand). Both made the speed/cadence sensor discoverable.You need the zwift companion app and that can connect devices, it acts as a bluetooth bridge, not sure about ant+ as ive only ever used it for the bluetooth element. I have my HRM and Zwift controllers connected through the app and trainer via direct connect, but before that it was done via wifi, but my trainer is a kicker v6 so that made that viable.
Thanks mate. Bit rich for my blood and intended use case --- GM3 probably fine?This may not be as cheap as the GM3 or Mirafit, but it's on offer and might last longer?
GymGear Multi-adjustable Bench
No worries. Yeah, GM3 probs ok, though I've never tested it... You'll just have to take it back if it starts rattlingSo I plugged in a new fangled BT 5.3 USB (TP Link) and an ANT+ (no brand). Both made the speed/cadence sensor discoverable.
