- 24 Mar 2018
- Brighton
Thats why I posted the buffer bloat test but he seems reluctant to post it!If it's full fibre then that's not the case.
I think it is something to do with their end that monitors and adjusts with new install. That's what I gathered from what the engineer said.
Try the same test again using Edge instead of firefox, I assume thats using a network cable ?![]()
Bufferbloat and Internet Speed Test - Waveform
View the full results, and test your own bufferbloatwww.waveform.com
Here is edge and it is wired on my old network cableTry the same test again using Edge instead of firefox, I assume thats using a network cable ?
Hi there, is there a link to a Virgin Media Live chat link who deal with retention or a specific number worth calling? The number i've been calling to try to negotiate is the number 0800 952 2277 - opt 4 - opt 4, but on that number i'm clearly dealing with the department who do not offer a worthwhile deal, there offering the price for the Gig 1 of £43 which initially when I said I was going to cancelled I was offered £34 which I didn't take up as I was planning to go to another provided, but they where unable to install their service.
Unless I was using their TV package with sports etc, there is absolutely no way I would be using VM broadband if I had CF available.
Proper fibre is just a much better product with much better latencies.Are people's experiences with VM really this bad? I guess I have never had to call their tech support as I've never had any issues. Granted the contract re-negotiation/renewal call every 18 months is a real pain. I believe the best way to get tech support if you need it is actually via the VM forums, unless you are reporting a critical fault.
I am a broadband only user, I got rid of my VM landline 5yrs ago.
As I said previously. I got lucky the other day getting that Brit lass that dealt with my VM disconnection. I said to her about hearing horror stories when leaving and she said well I don't want your last experience with us to be a negative one as the horse has already bolted and hope that one day you won't dismiss us altogether. Real Customer service. I couldn't fault her one bit.If you don't notice any issues they're generally fine, unless you have to talk to them. Which is one of my biggest gripes with VM, they do some shady things and make things overly difficult for people to leave them.
I'd go CityFibre or whoever and revert to that M250. I have went with a different ISP for full fiber and not 1 single issue since last Friday. 900/900 overkill most of the time for my needs.I just called up Virgin, they said I have until 11 Jan to step back to my previous M250 contract which ends on 15 Feb. I think I will loose my £35 'connection fee' though and will have to pay the difference for the days I have used the Gig 1.
I may step back and give CityFibre (IDNet or Lit Fibre with a static IP) a try then, and if I am happy, cancel Virgin. It may mean a month of overlap, but I don't mind, I would rather make the right choice. I work from home so connection reliability is very important.
It’s great.I,m getting 1 gigabit installed on Friday , and it’s using the XGS /PON technology, what are people’s thoughts on this set up please ?
There are ways around it posted in here, albeit I think one involves custom non-VM firmware. There's also nothing to stop you disabling wifi on the 5x and using your own instead.Only downside on my end is that you're forced into the 5x which currently does not have modem mode so you cannot install your own router/mesh system.
Whilst the extenders from VM are OK, I don't get great speed in my garden office.
Hopefully they'll release the firmware for it at some point so I can install my own mesh network.
