- 28 Jul 2015
All this testing by HUB and HC is in some ways misleading
HC used old unsupported hardware and are then surprised they had issues
Intel supplies minimum specs they chose to ignore and even then these specs start at what is five year old hardware
Pointless testing in Ryzen 2000 series as that only had PCIe Gen 3 on the IO die
Why test at 1080p when it's marketed as a 1440p GPU ?
I have had my B580 since before Xmas and run it on 8600G at 1440p with no issues
HUB can't even seem to get their bench runs consistent as the 4060 performance in Spiderman is very different in the new testing Vs their B580 review at 1080p very high settings 90fps Vs 127fps both on the 9800x3D
At least provide both 1080p and 1440p results
Don't understand the "it's for 1440p", "test at 1440p" argument. Why?
Lets break it down a bit and isolate one result:
Warhammer 40,000: Space Marine, 1080p
If we run the test at 1440p, will the B580 get more than 53fps? No.
Will the 4060 get less than 74fps? Yes, could even be less than 53fps.
Does that make the B580 "better"? In my opinion, no, being limited to 53fps is bad regardless of resolution.
All testing at 1440p will do is hide the problem that's being explained...
I guess ignorance is bliss
). Some of them will probably be CPU intensive. How many games yet to be released will you buy during the lifespan of the B580? Some of them will probably be CPU intensive.
