Well, you go in with low expectations and somehow come out disappointed.
That is a major disappointment.
3 8 pins makes me think it surely can’t be that bad. The ASUS TUF 7900GRE had two while the 7900XT and XTX had 3. There’s no way AMD haven’t improved efficiency by 10% going from one gen to another right?Asus has decided to announce its AMD card
This is the Asus TUF RX9070XT. A triple slot cooler with 3x 8 pins for power. Asus says they've stopped using thermal paste and are now using phase change thermal pads for the coolers. They confirm the 9070XT has 16GB vram and DP2.1 ports. It also comes with an antisag bracket
And here is the Asus Prime RX9070 (non XT model)
This time it's a 2.5 slot cooler, and also 3x 8 pins for power and 16GB VRAM
It was just weird and a mess. From the audio issues to the sort of strange moment a member of staff walked on stage to hand over a H series chip and then 15 seconds comes back to take it away???Well that was disappointing.....
we already knew we weren't getting any.Yeah some performance details and pricing ?
Apparently the card will feature a triple-fan WindForce cooling system with Hawk Fans, and a dual bios with “server-grade thermal conductive gel.”
Edit: Also, finally phase change thermal pads.
Yep they've obviously thought we need to do something.Incredible that the AIB’s are announcing their models even though we have barely any information from AMD. The AIB’s are probably and quite rightly furious about the whole thing.
This has to be one of the worst GPU ‘announcements’ I’ve ever seen and I am a bit of an old AMD fan boy. If you are going to announce it, just do it properly.
Here is the Gigabyte model of the 9070XT Aorus. Also triple slot and triple 8 pins power
So size/cooling-wise it improves nothing from a 7900XT and power-wise it could pulls more power than last-gen high end (even Red Devil RX7900XT is just 2x 8pin)?
As soon as that slide leaked it was obvious the price had to be less than £500.
If they release the price now at less than £500 with no product they kill old stock sitting in stores.
If they release a price higher than that they get panned and have to drop prices later anyway.
So they pulled it which has its own amusement watching people go into meltdown.
