CES 2025 AMD & Nvidia Keynote Live Chat [06/01/25]
  • Thread starter Thread starter Hostile_18
  • Start date Start date
So now $2k isn’t considered ‘all that bad’ as it’s lower than the supposed numbers doing the rounds the other day. :cry:
Hook, line and sinker.
**** that. We all knew that.
What about the 5070 and 5070 Ti price? What's your thoughts on that?
575 watts for the 5090
360 watts for the 5080
300 watts for the 5070ti
https://i.~ibb.co~/sFYZykB/Screenshot-2025-01-07-163650.jpg
Yeah so 5090 is 30% faster than 4090 in native performance
And don't forget, 5090 uses 28% more watts to run, 30% more performance for 28% more watts. Not very efficient generation
Most likely with the 4090, small undervolt brings wattage down massively at 0 cost (if you give a slight overclock also).
Yeah so from that only only DLSS4 feature exclusive to 50 series is MFG, so unless you /need/ 240fps at 4K with path tracing, then the other DLSS suite improvements are coming to 40 series too , which automatically means an fps uplift and latency drop which is what I predicted the other day.
The Neural stuff for texture compression is mostly important for the lower VRAM models obviously.
