- 7 Sep 2020
- Gods Country
Ordered 30 x 4x2's @3.6mtrs ready for the shed build......
You building it off dirt again or going to isolate it?Ordered 30 x 4x2's @3.6mtrs ready for the shed build......
built off dirt, what you talking about dlockers??You building it off dirt again or going to isolate it?
This previous post you made looks no where near ready for constructing a new shed. It is just a patch of dirt?built off dirt, what you talking about dlockers??
the 1mtr at the front is dirt - the 5mtr by 4mtr section for the shed is 2 tonne of yellow gravel and stone - there is zero mud in the area the shed will be on, ontop of that there will also be another 2 tonne of 14mm to dust to level the area and make it fully flat.This previous post you made looks no where near ready for constructing a new shed. It is just a patch of dirt?
Why are you always so senstive?the 1mtr at the front is dirt - the 5mtr by 4mtr section for the shed is 2 tonne of yellow gravel and stone - there is zero mud in the area the shed will be on, ontop of that there will also be another 2 tonne of 14mm to dust to level the area and make it fully flat.
Like i said yo you before, unless you know the person personally that your talking to, know their background, then keep your lips buttoned, its stops you making yourself look really silly
like 50 million sheds have been built on in the past...... it will be a base of 4x4 timbers, sat on blocks, with membrane under the timbers so water cant get wicked up from underneath.Why are you always so senstive?
So you are going to build a shed on top of gravel then? :S
I was just clarifying because you said you had bought 36 timbers 2x4 like you were ready to get going; yet your foundation is gravel.like 50 million sheds have been built on in the past...... it will be a base of 4x4 timbers, sat on blocks, with membrane under the timbers so water cant get wicked up from underneath.
why do you think that one picture is the finished area for the build, that picture was just showing that area has been cleared of the old greenhouse and old timber stacked away.
)no issues with building on a gravel foundation dlockers, helps with draining water away from the surface of the timbers......dont have to have some elobrate base made out of screw rods, bolts and washers... its a shed, not a house or a home officeI was just clarifying because you said you had bought 36 timbers 2x4 like you were ready to get going; yet your foundation is gravel.
Yep. Installation guide includes the steps for... I want to call it offline mode? It might be isolated mode or something.Looking into the Hive V3 thermostat bundle, am I correct in thinking I can install the receiver and smart thermostat now and then add the hub once we’ve had internet installed?
A proper insulated concrete pad is "best". Key word is insulated; not just concrete (or god forbid pea gravelI too am looking at building a cabin this year but mine in fact will be a home office and fully insulated so I do want to construct a good base. Looking at different options. Mine will be about 4.5 x 2.5 metres and under 2.5m tall. Do you think the whole thing is doable for under 10k guys? Total DIY it will be. I want to prioritise warmth and only want one door and a smallish window. Maybe two windows.
Should've used insulated gravel.
Just been and picked it up, installation guide calls it “standalone mode”.Yep. Installation guide includes the steps for... I want to call it offline mode? It might be isolated mode or something.
If you want a "proper job" and have good access I'd do a concrete slab then a couple layers of engineering bricks and insulation.I too am looking at building a cabin this year but mine in fact will be a home office and fully insulated so I do want to construct a good base. Looking at different options. Mine will be about 4.5 x 2.5 metres and under 2.5m tall. Do you think the whole thing is doable for under 10k guys? Total DIY it will be. I want to prioritise warmth and only want one door and a smallish window. Maybe two windows.
I’ve got a summer house you can have if you’d like to come and dismantle itI too am looking at building a cabin this year but mine in fact will be a home office and fully insulated so I do want to construct a good base. Looking at different options. Mine will be about 4.5 x 2.5 metres and under 2.5m tall. Do you think the whole thing is doable for under 10k guys? Total DIY it will be. I want to prioritise warmth and only want one door and a smallish window. Maybe two windows.
everyone knows you insulate above the gravel..... in the same way dlockers and buffman have insulated above the soil on their workshop/office builds.Should've used insulated gravel.
