*** The AMD RDNA 4 Rumour Mill ***
That 9070 XT Timespy result looks wild. Average temp, 54c. Air-conditioned room I would expect but still....
Potentially 4080 perf priced below £500? AMD have an opportunity here.
But we all know what they say about AMD and opportunities...
Also had an interesting random theory... what if AMD's delays are software/driver-related?
E.g. the regular raster/RT perf is sorted, but FSR4 and new AI frame-gen stuff isn't ready yet?
Cos they probably would want to show any new tech/software when they 'officially' announce the cards.
It's less of an impact if they show regular raster numbers before showing fancy FSR4 boosted numbers.
Also would give them an opportunity to show framegen FPS beating a 4090 and beating Nvidia at their own mischief :cry:
FSR4 looks great vs 3, and that's performance. The steps is a good example but the confetti was also where it shines.
Daniel is convinced at least.
It does look impressive and yes it says "Developed for RDNA4" it could be backported to RDNA 3 and again yes AMD are looking at that.
Also i agree the wording, again suggests that any game with FSR 3.1 already in can be pushed through the FSR 4.0 algorithm through a driver toggle, FSR 3.1 is similar to Nvidia's DLSS 3 where the .dll can simply be swapped out for a later DLSS version, AMD do the same with FSR 3.1 so there is no reason, as with Nvidia and DLSS why you can't just have a driver toggle for it.
The thing about RT that Daniel is missing, not just him lots of people seem to be missing this.
RT performance is not linier on AMD GPU's, this is because of the difference in approach with how AMD vs Nvidia do it, AMD's RT architecture is Integrated, what this means is AMD's RT component is on the shader core, Nvidia have a dedicated RT cluster on the GPU, the benefits of AMD's approach is it is faster in latency terms, the down side is the more the GPU needs to work to produce a Ray Traced Image the more bogged down it gets because its sharing the rescores between RT and Raster given they are separate functions on the same shader, with Nvidia because it has a dedicated RT cluster it is only limited by how fast that cluster is, its independent from the Raster performance.
AMD can improve their penalty by making their RT ever more efficient and powerful, so that it just takes more to get it bogged down, this is what AMD are doing RDNA 4 vs RDNA 3, so a game that is not demanding of the RT hardware would not necessarily gain performance 'Relatively' but in games where the RT is brutal, like Cyberpunk RDNA 4's RT is that much more robust so it doesn't suffer the heavy RT penalty and with that you get an improvement in performance.
So that Speed Way Benchmark really doesn't tell us anything, what we need to see is how it does in Cyberpunk.
Part of this explained from a Developers point of view in the video and an Example of this in benchmark charts below.
If this was 4080 super ish performance for 350 Max even with aib then AMD will win this generation.
But we won't see those prices. 350 is usually the max the majority willing to spend if the performance it's warranted
If the 9070 XT offers 4080S performance at £450-£500 then the 9070 might be around £350-£400 and not too far behind on performance?
Isn’t RDNA 4 another DOA interim gen with UDNA coming in 2 years and perhaps FSR5 with dedicated AMD tensor cores. (The 9070XT doesn’t have this if I’m not mistaken).
Don’t want to be in a situation like I am with 7800XT and allegedly not be able to use FSR4?
What a ridiculous post. Sorry but to expect AMD to undercut Nvidia by at least 50% is utterly preposterous.
If they can undercut Nvidia price/performance by 25% that would make a difference. 30% would be amazing, but 50% - 60% is starting to get insulting on AMD.
