Why don't they just turn it up then?!They don't have enough pressure to pump the water up to higher elevations because they rely on mavity in their towers to create the pressure, so yes they are having problems with mavity
The government should step in and make all the insurance companies pay for the rebuilds etc....
Why?
rhetoric
/ˈrɛtərɪk/
noun
the art of effective or persuasive speaking or writing, especially the exploitation of figures of speech and other compositional techniques.
If we blame climate change on this, it means equally so, a person who leaves his tap on, which floods his apartment, can blame rising sea levels for flooding his flat.
Local climate is not global climate, in that region of the world, this problem has been there since the start.
Small fires have consumed material, preventing larger fires, the introduction of a zero fire policy has meant, no controlled fires are being done, neither are dry/dead flammable material is being removed in compensation.
So eventually, the odds of this happening (a big fire enough to be on global news for a long time), is 100%.
The only real question is why on earth did any insurance company sell fire insurance for the last 3 decades in that area? Thats what i want to know. My only explanation is, were such a thing to happen they would declare bankruptcy as they limited their liability in such a way via the use of multiple companies.
I have already told you, this has been massively written about last 30 years, i studied this nonsense in university. You have fallen prey to climate change rhetoric and cannot do anything except point to "facts".
They used to cover for fire. They should be made to include that cover for anyone living in those areas that pay for insurance.
Insurers don't have a magic money tree, if you force them to insure an uninhabitable area then everyone else pays for it with higher premiums.Because, they withdrew insurance against fire!!
They cant force people to live elsewhere.
I've read some utter nonsense on this forum but this drunk, nonsensical drivel probably tops it all.
I did actually study climate change at university as part of my Ocean Science degree - and because I have been bestowed with really basic scientific training, I can assure you, what you're writing is absurd.
Yes global climate change causes local disasters, Christ on a bike.
The thing is, science doesn't care if you believe it or not, its true, whether a random human being accepts it or not.
I don't even know how you pseudo - logic your way into a conspiracy theory about the insurance industry either.......what happened really is - science predicted an ever increasing likelyhood of this happening in LA, so the insurance companies decided it would burn sooner rather than later, so 6 months ago bailed on their customers......and now they won't pay out.
Not hard to understand - and as much as these insurance companies are vile, immoral blood sucking leeches on society - they dont have issues dealing with reality, especially when it comes to risk assessment, accepting that knowledge has saved them hundreds of billions and they remain rich.
Yes looks a impossible task currently. More about preventing it getting to neighborhoods as opposed to putting them out. Just so dry everywhere and with the wind any embers just start new ones. Watched some vids of that mustard plant going up in flames, crazy how quick it burns. Trouble is once these fires are out the mustard plant grows back quicker than any other vegetation as it grows freely in burnt ground.Sounds like these fires are still very much not in control.
The mavity, or the pressure?Why don't they just turn it up then?!
or some facts california seemed to have 'class A roofs post 2019'
Wood Construction and The Risk of Fire
Whenever the topic of wildfires comes up, someone always mentions [1] that US homes are built almost entirely made from wood, that it’s senselessly risky to build homes out of a material that burns, and homes should be built from some non-combustible material like steel or concrete like they do...www.construction-physics.com
The design requirements for a wildfire resistant building are distinct from normal fire resistant construction, and there’s a variety of building codes and design guides for construction in wildfire prone areas. The ICC has the WUI building code, which California adopted as chapter 7A in their residential construction code. Colorado and Montana (and perhaps other states) have standards based on the “Ignition Resistant Construction Guide”. FEMA has a Homebuilders Guide to Construction in Wildfire Zones. NFPA has Standard 1144, Standard for Reducing Structure Ignition Hazards From Wildfire.
Unlike normal building codes (which focus on evacuation), these codes are much more focused on preventing the buildings from catching fire in the first place. They all make relatively similar recommendations:
Fire-resistant (Class A) Roofs: The roof is the most vulnerable portion of the house in a wildfire, and the roofing should be an assembly that will resist the spread of flame. This can be materials like tile, concrete, or metal, but asphalt or even wood shingles can be made class A as well. Anything combustible should be either fire-retardant treated or protected with a layer of gypsum.
Non-combustible or fire resistant exterior elements: Things like exterior siding, windows, doors, and decks should all be of noncombustible construction, and designed to be fire resistant. Brick or cement siding instead of cedar siding, double-paned windows, etc. If there’s a deck, it should be either noncombustible or covered with protective gypboard or fire retardant
For wildfires specifically, we see something similar - construction details such as fire protected eaves and class A roofs, along with things like community density, matter far more than whether your home is wood or steel.
