How is PS2 emulation on the new breed of handhelds? Can they maintain 60fps? I really need some portable Initial D and Godhand!
Saw the TrimUI Smart Pro can be hand for under £50 but still holding off at the moment. I think the extra functionality of YouTube Netflix and so much makes the device more usable.
I do want to re live pokemon Yellow soon though haha.
I had ruled the brick out but I don’t know why. It would be a very close like for like for a gameboy colour.Buy a trimui brick because you never just own one hand held
Don't let the lack of YouTube stops you, you always have your phone anyway.
Good point, thinking there would be few and far between scenarios where I would “need” that function.
On AliExpress, do you have a preferred seller or just get consoles from cheapest one you can find ?
Thinking of that tiny A30 or Brick for starters... Suppose brick gives option to customize ?!
Let us know how you get on. I am tempted but not for 150 sheets considering the Brick was only 40. However, as much as I think the Brick is quality, it is extremely small for my fat man hands!Just got my Miyoo flip today, will have a play a bit later but it looks much better than I thought it would and the hinge actually feels really good.
Also the buttons are nice and not too "clicky" like the Anbernic clam shell one i had.
What device? Presuming if you're (attempting) to emulate PS3 it's a Steam Deck... or you meant PS2. AethersX2?This thing is taking forever to set up....I am only part way done.
First, I formatted my 256G micro SD to FAT32....only notice my error when some of the larger games over 4gb wouldn't fit.
Then the bigger problem. The github page for the PS3 emulator NetherSX2, according to Russ from RGC, there is a .bat file...however, there isn't now! So is there another PS2 emulator that I can use?
Something had to be said about this screen, it's amazing!
Needs to be formatted as exFAT
I followed Russ's guide literally a couple of weeks ago and was all good on PS2 side.
Retroid Pocket 5.
AethersX2 is no longer supported.
I was doing that last night, the NetherSX2 I downloaded, when unzipped, the .bat file he was referring to is now a .CMD file.
Do you still have that download in your hard drive?
I think I used Classic version, which has the BAT. I assume the Patch version cmd is just the same?
Retroid Pocket 5.
GitHub - Trixarian/NetherSX2-classic: Continuation of NetherSX2 based on AetherSX2 3668
Continuation of NetherSX2 based on AetherSX2 3668. Contribute to Trixarian/NetherSX2-classic development by creating an account on GitHub.github.com
NOTE: No APKs are provided due to licensing issues. You have to build it yourselves using the above methods
