- 4 Feb 2011
I’m a bit undecided…
I did a full system upgrade back in October:
Ryzen 9950x
ASUS x870e Hero
96gb Corsair Dominator Titanium DDR5
Given that my system is largely for productivity due to my line of work, I skipped a generation and stayed with my trusty 3090, with the expectation of upgrading to a 5090 on launch.
As much as I would love to get back into gaming and get more out of my system than just work, toddler and work commitments mean that I doubt that will become a reality any time soon; and couple that with the fact that my main monitor is a 60hz Dell 8k 32 inch (280 PPI makes sense with what I do and I could never go back to 4K) I’m starting to think that grabbing a 5090 would be a little bit pointless now.
Should I just grab a 2nd hand 4090 now? Get a 5080? Skip another generation?
I’m feeling the GPU upgrade itch and the price doesn’t really concern me, it just feels a bit wasted if I won’t be coupling it with a high refresh rate monitor and gaming heavily.
Can you not get or use another higher refresh rate monitor just for gaming? 27" 4K 240Hz display + 5080 (With MFG with games that support it) for probably the cost of a 5090.... if you can afford the 5090 after such an expenditure then a 5090.
I will say though would be interesting to see how the 5090 does at 8K 60hz. I want a 8K 120Hz monitor (for 2 years now, still waiting)
so should be considered. Now you mentioned that upscaling quality improvement, I'm already considering it
