Caporegime
- 7 Apr 2008
- Lorville - Hurston
9950x3d seems like the sweet spot for gaming and productivity9800x3D has 8 cores, it's not great for productivity.
It's a gaming orientated CPU really
Yup, although I chocked and ordered a 9800x3d, I don't do any productivity work just pure gaming so was like why am I waiting for the 9950X3D?9950x3d seems like the sweet spot for gaming and productivity
Also 9950X3D will be +30-40% more expencive and can have the same problems with the parking cores and big latency like a 7950X3D...Yup, although I chocked and ordered a 9800x3d, I don't do any productivity work just pure gaming so was like why am I waiting for the 9950X3D?
Exactly, there are ways to mitigate but they're a pain - e.g. bios option like on Asus and Gigabyte to disable the slower CCX or using project lasso etc. although according to rumors, that'll be fixed in the next gen CPUs so might be a good idea to skip higher endAlso 9950X3D will be +30-40% more expencive and can have the same problems with the parking cores and big latency like a 7950X3D...
Except it doesn't. Trust me I did some research and actual real world use by many users have stated there is no latency with the previous 7950x3dAlso 9950X3D will be +30-40% more expencive and can have the same problems with the parking cores and big latency like a 7950X3D...
Yes to a certain extent. But if it is for something which earns you money and time is money wasted then it not.Im sure a 9900X3D could be fine too depending on what you do.
I am guessing it will be roughly 700. How much did the 7950x3d release for?I do wonder how much the 9950X3D will cost, both its MSRP and actual price. I don't expect the same fiasco as the 9800X3D, but you never know
I believe it was £750. Given the 9800X3D is going for £500+, I could see the same price tbh.I am guessing it will be roughly 700. How much did the 7950x3d release for?
It wouldn’t surprise me. Let’s say it is on par or fairly close to the 9800x3d in gaming and surpasses something like the intel 285/7950x3d it seems like it would enter at that price point if it had the productivity output to match/surpass.I believe it was £750. Given the 9800X3D is going for £500+, I could see the same price tbh.
Thats my next upgrade9950x3d seems like the sweet spot for gaming and productivity
Will it outperform my 3960x thread ripper for productivity?Thats my next upgrade
That's probably close to what is expected. Especially if you pushed the boost as well to 5.425Ghz (+200Mhz) or edited other settings for the CPU.I have custom water cooling and my 9800x3d gets to 80'c on load sometimes. Have I made a poor mount? Also using new thermal take Helios solid thermal interface material.
In the begining I have the same issue with Artic Liquid Freezer III 360 + MX6 paste,stock i hit 80-83C in cinebench. After remount and MX4 i have 78-82C with [email protected] in cinebench,in games 52-58C. For me the best paste is Arctic MX-4, Im use it from years.I have custom water cooling and my 9800x3d gets to 80'c on load sometimes. Have I made a poor mount? Also using new thermal take Helios solid thermal interface material.
If You want to have the best termal performance You will need to mode your cooler block mount or buy a new one which have a offset mountI can't mount my cooler offset, its an AM4 block with AM5 standoffs; fortunate that I can reuse it. I'm looking at some m4 hex bolts on screwfix, but not sure 16mm isn't too long. If I'd had to guess I'd say original screws were 12mm. Hard to say whilst typing this on the PC with block mounted.
