DETROIT — General Motors is recalling more than 740,000 small SUVs in the U.S. because
the headlight beams can be too bright and cause glare for oncoming drivers...
The company is recalling GMC Terrain SUVs from the 2010 through 2017 model years.
www.nbcnews.com
"The original design of the LED headlights available on the Limited and Ultimate trims produced too much glare for oncoming drivers to be rated higher than poor by IIHS"
Kona's built after May 2018 have new headlight projectors. https://www.cars.com/articles/2018-h...1420702695389/ "The original design of the LED headlights available on the Limited and Ultimate trims produced too much glare for oncoming drivers to be rated higher than poor by IIHS...
www.hyundaikonaforum.com
"The incorrectly adjusted headlights exceed the range specified by Federal Motor Vehicle Safety Standard 108 by just around 0.15 percent. Said headlights may create glare for oncoming traffic, therefore increasing the risk of a crash. Mercedes-Benz started investigating this concern in late 2021, following a series of tests conducted by the IIHS".
My point stands that if new brightness standards are set lower than the output/alignment of existing cars, recalls can and will be issued to correct the problem by manufacturers.
