Friday was spent fitting the amp and doing the doors of my GT4. I didn't get as many pics as I planned as the amp install chewed up way more time than I expected so I was under a bit of time pressure to get the doors completed on the same day - a good friend let me use his workshop on a quiet day and I didn't want to put him out rolling into two days.
Getting the Conductor to where it needed to go in the centre coin holder bin thingy took more time than expected. I've cut the bin and made a mount for the conductor. It's not perfect but it will do. At £86 a throw, I can live with it.
Very gingerly took the seat out
Physically, the new setup fitted nicely into the space. I took a separate fused feed from the battery.
Quick break for food and contemplation of life etc.
I didn't want to take the inner plastic panel off the doors. The little white clips looked like they probably would come out but not without some of them breaking so I cut the metal backed material into smaller squares and stuck them down as far as my arm would go. I then covered them with this peaky material.
Couple of small dramas that took up the most time. Got it all in and nothing worked - yay!
I was originally going to use a Director which requires power - I took this from the 38 pin connector. When I changed to Conductor and removed the wires, I re-wired the ZEN the wrong way round. Fortunately not killing it in the process.
2nd silly thing was remote on - I could not work out why the amp was still on when the car was off. I could pick up the amp on Bluetooth scan and the Conductor was still live. Took the amp back out and changed the remote on from the ZEN to the 38 pin. This seemingly had no effect.
Some time later - I realised the Bluetooth was still on and some parts of the amp and zen seemed to be on even with the battery disconnected because I still had the car plugged into the trickle charger!
I was taking off the negative terminal but the charge lead takes the negative from the body, so there was some element of circuit keeping the amp somewhat alive.
