Google Pixel 8/8 Pro & Pixel Watch 2
With the limit to 80% charging how do you force it to go higher when you need to?
Just turn it off...? (Search limit in settings)
I leave it one while I'm working at home for days, but if I have something where I'm heading out for the day, I might turn it off and charge over 80.
Seems to me there should be something in the drop down menu so you can quickly toggle it on and off.
Has anyone had any issus with wireless charging since the December update?
My 8 pro was working absolutely fine, is only a month or so old and since the update it either won't recognise the wireless charger or it recognises it and then disconnects and reconnects constantly, could be a coincidence and there is a fault with charger or phone but seems quite a coincidence when it worked perfectly previously
My watch stopped charging a couple days ago. Have an open ticket with Google. Possibly replacement (sent all photos etc they asked for), I'm assuming it'll be a refurbished 2
That offer on Google Store for 8 Pro and Fitbit 6 for £499 looks too good to pass up with the extra offers.
Have an older iPhone SE so trading that in with a Perkbox code and £75 off on my AMEX makes it £326ish.
Could probably sell it on for profit, but can try and see how I get on with the camera compared to my S23U.
My 8pro case is falling apart... Dropped to many times lol
Need a case that's grippy to hand but less to clothes... Google one is so sticky to material it's hard to put it in to pockets... Big pain when cycling and you try to get it out..or in...
Any good recommendations?
Thanks !
Thanks !
I moved from the case you have to the Mous Walnut one. Couldn't be happier...
It was heavily discounted at the time.
I finally updated my pixel 5 to a pixel 8 pro (which I snapped up on offer), what is the easiest way to transfer all my phone settings (including my mfa settings, I use both the google and microsoft authenticator apps)?. I plan on keeping the pixel 5 as a backup phone so don't want to wipe it.
Also are the branded more expensive phone cases like Spigen which cost more than double/triple as non-branded ones available on ebay but look very similar worth it?. I have for my last 2 phones had Spigen tough cases, but for previous ones I had cheap ones brought from ebay.
Thanks in advance :)
I have the Ringke Onyx case, which is probably the most I've ever spent on a phone case (so far). But I really quite like it. The case is slightly textured on the back, which not only feels good but aids in helping stop the phone slipping out of your hands. The buttons don't feel mushy with the case on, like what has happened with other cheap cases from the likes of eBay.
It's down to your own personal preference what you go for, but that's my own opinion as a Pixel 8 owner.
Anyone had WiFi and Bluetooth issues recently ?
My phone is ok when home on the WiFi but then when I leave and it disconnects from my home WiFi next time I try to connect to a WiFi the WiFi is turned off, I toggle it on and it doesn't scan and then turns the WiFi off ?.... The only way to connect to WiFi is to restart the phone ?
