AMD Ryzen 7 9800X3D
  • Thread starter Thread starter Hostile_18
  • Start date Start date
Try -025 or -30 PBO and set +200Mhz for max boost override, scalar x10, and set PBO limits to Enabled. This should pretty much max out performance using PBO and you'll get clock speeds up to 5.425Ghz. A real quick and easy overclock that should be plug and play on all samples.
So scaler 10x is not detrimental to the chip?
Testing a new memory tune, and we've passed 261MBs in Karhu. :cool:
What sort of temperatures should I ideally be looking at with J2C boost settings? It's showing 54160MHz at 90c running cinebench.
It depends on your cooler and rest of the cooling.
Mine with a CO of -35, +200Mhz boost has my 9800x3D hitting just under 80C with Cinebench R23 at 5.45Ghz. But it sits underneath a Noctua D15 G2 (LBC version) and using offsets. Prime will send it to low mid 80s.
I've got a corsair H115i pro AIO sat inside a Phanteks Evolve X case.
Probably the best system upgrade i've done in a while, using my RTX 3070 while waiting for a 5000 series card and I can tell a big difference in every game just how much smoother it is compared to my old Ryzen 5 3600 setup, don't notice much of a big difference with non-gaming but I only really use the PC for normal use and work but overall gaming side I thought i'd think it was a pointless upgrade.
Glad to see I just waited until the initial rush died down and bought at right time at £499, not moved much on either side of this
