NVIDIA RTX 50 SERIES - (PRE)ORDER DISCUSSION **NO COMPETITOR HINTING**
You’d hope so - I agree. Using the adaptor they give you is just ‘redundancy control’, to be extra safe and to avoid any stress of them interrogating you during the RMA process. You don’t want them saying “you’ll have to take this up with you PSU provider” - which I would hope is unlikely but it would be particularly frustrating!
But yes, as long as you follow the instructions that come with the GPU and follow that to the letter you should be OK re: RMAs.
I've ordered an Asus card, and using Asus ATX 3.0 power supply at present with PSU supplied PCI-E 16-pin x 1 (both PSU & component side). So, if something goes wrong- interdepartmental fight? I'm sure it was the Cybenetics boss that said he would, and does, use the cable supplied with the PSU. And Asus like to highlight that Cybenetics gave the PSU A+.
Aware that not all PSU's have a 16 pin on the PSU side. But, 'we' still shouldnt be thinking 'hopefully'...on expensive GPUs.
We’re in total hypotheticals here, who knows how anyone will act… but…
If the 50 series GPU uses a H++ connector and you plug in a native 12 volt cable into a H+ PSU socket… if there is an issue they might turn around and say that you knowingly made and took a risk on a mismatch. On one hand, this would seem ridiculous because everyone is saying these cables are the same and everything should be compatible, but then look at this info from Coolermaster:
H+ and H++ connectors and cables are compatible with one another and will work well. However, by combining H+ with H++ cable you will not receive all the additional safety benefits that ATX 3.1 brings. Specifically, combining H+ and H++ loses the tighter connection provided by using only H++ connectors.
…?! Very difficult for anyone to navigate with confidence.
There’s a big Reddit thread here of loads of people trying to figure out what the deal is and who, if anyone, is being misleading.
I mean weren't a lot of these PSU's or cables themselves sold on the basis that they'd be fine for future GPUs too? If they're not that's not going to look very good.
I purchased a cable from Corsair for my 4090 which went straight into the PSU rather than using the one with my GFX card.
It was pretty expensive and was from Corsair so I trusted it would be good enough and my 4090 hasn't caught fire YET.
That's what I'm using. My 5090 hasn't caught fire either. Yet.
I upgraded from an EVGA 750 to an Asus TUF 1000 gold with a direct 12vhpwr and I haven't had a single issue with it. Recent did a rebuild for my 9800x3D and decided to inspect it at that point. Not a thing wrong with it so was just going to use it for the 5090 when I eventually receive it.
An unexpected benefit I might have with the H6Flow case is since I'm using an eATX board it slightly overhangs resulting in some of the inbound airflow from the 3 front angled fans to been routed into the rear chamber. I should be able to fan the flames when I turn on Multi Flame Generation
I have the old RM1000x from 2021, I got the 2x 8pin to 12vhpwr from them too, hoping to use it when my card arrives. Is that the same kind of cable you're using?
I got a brand new RMX1000x delivered from Corsair a couple of weeks ago. Should what I need for an RTX5090 be in the box?
Well, Astral 5090 is now the best 5090 IMO, following the fan speed fix and the fact it's the only GPU that will alert you if you have a dodgy cable!
It was always the best looking to me, just let down by the insane noise of the 4th fan. With BIOS update this is now nice and quiet :)
Will still pickup a 5090 FE if I get the chance though!
You mean the Suprim Liquid OC… I’ll give your astral 2nd place
