*** The AMD RDNA 4 Rumour Mill ***
I doubt they do, they may have the cards in hand but it's unlikely they have drivers for them.
AMD wouldn't be asking for HUB and potentially other reviewers about pricing if they didn't know about performance.So either they now have the drivers or AMD has furnished them with expected performance pictures.
9070XT is a large GPU no matter what AMD calls it
It has nearly 10 billion more transistors than the rtx5080!
It fit's perfectly with previous AMD generations:
1.)RX6700XT(Navi 22) - 335mm2 and 17.2 billion transistors which was only slightly less than the RTX3070TI(GA104).
2.)RX7800XT(Navi 32) - 346mm2 but spread over dual chips - 28.2 billion transistors. Was in-between the AD106(RTX4060TI) and AD104(RTX4070TI).
Though if Navi44 is half a Navi 48 it will have a similar number of transistors to Navi32.
So AMD's GPU is smaller than GB203, 379mm vs 350mm, on the same 4NM but AMD's GPU has more transistors? How did they do that????
AMD is probably having denser caches than Nvidia?
Do we know if AIBs for AMD actually improve the build quality on the cards over and above what AND deem as the base spec?
Watching the Buildzoid tear down on that blown 5090 Astral terrifies me that ASUS are literally just cutting so many corners with their cards, I’d be interested to know how much actual difference in components there are on the entry ASUS 5090 to the Astral version as I suspect very little and they are literally just charging more for the name, slightly higher OC, possibly better binned silicon and likely a better cooler.
AMD is probably having denser caches than Nvidia? Last generatio
Analogue vs Logic, Analogue being memory / cache is less dense than Logic, GB 203 has about 80MB of cache, Navi 32 has about the same 80MB of cache, i don't know how much cache Navi 48 has but its about the same size at 350mm.
Differences in packaging design can also increase transistor density, AMD are very good at packaging, its one of the things they specialise in, its something they do far better than Intel which is one of Intel's problems vs AMD BUT..... the difference in transistor density here is 28%, that's flipping huge, so it can't be that either.
Differences in packaging design can also increase transistor density, AMD are very good at packaging, its one of the things they specialise in, its something they do far netter than Intel which is one of Intel's problems vs AMD BUT..... the difference in transistor density here is 28%, that's flipping huge.
AMD has a lot of experience regarding their CPUs in optimising for density. They have been using large caches for both their CPUs and GPUs for a while now,but each generation they are doing more with less.
The RX7700XT has half the L3 cache of the RX6700XT,but only 12.5% more bandwidth but still is almost 30% faster overall.
The RX7700XT has half the L3 cache of the RX6700XT,but only 12.5% more bandwidth but still almost 30% faster overall.
Yes, look at the size of AMD's Zen 5 core CCD's, 70mm (they are tiny) 16 cores amount to 141mm on TSMC 5nm, the Core Ultra 285K has 8 big cores and 16 little cores in a package of 245mm, its on TSMC 3nm, 3nm has a density increase of 70% over 5nm, if the 285K was made on the same 5nm node it would be about 400mm, the total size of the 9950X with the 6nm IO die is 265mm.
That is a serious cost problem for Intel vs AMD.
So ok i don't know, maybe...
The dropped the 4070 to $550 the moment the 7800 XT was launched for $500.
Fair point mate. Though as you can tell, I just don't think many folks noticed or cared for the 4070 dropping to that price, it was still a measly $50.
It would have been more impactful to drop $100 down to $500, but Nvidia were still reluctant to drop price by any meaningful amount. So I still stand by my point.
Either folks were going to buy Nvidia anyway or they weren't. And all it might have done is make AMD look 'only $50 cheaper'.
Even with the drop, the 7800XT was still a better card with more VRAM and raster performance. And not many folks would be turning on RT on a $500 GPU.
I guess we'll agree to disagree on that tangent.
Oh and performance-wise, I expect AMD will still be behind on FSR-vs-DLSS and RT, though hopefully not too far behind on RT. DLSS4 got a boost and even if a handful of old-timers like me can't stand DLSS/FSR, fans will defend those software technologies as 'adding value' somehow. Personally, even if there was a card that performed 1% better on price/performance, but had no DLSS/FSR, I'd pick that over the software-performance-crutch-nonsense. I consume old-fashioned real resolution at real frames only, thank you very much.
None of this changes the plain fact that AMD need to price the 9070 series to sell. They call them 70 class/midrange cards. Last gen the 7700xt/7800xt were mid range.
Hence the 9070 series should be following on from those and be priced similarly. Too far above $500 is no longer midrange, pushing into high-end, even though Nvidia is trying to push it as midrange. That price below $600 is where the masses can afford to buy, if they want sales, then price them where majority of folks can afford them.
That said, I expect AMD to disappoint/mess it up and price the whole 9070 series at $500+.
And even if AMD don't somehow mess up pricing, a discussion I had with someone during dinner today... well-priced desirable AMD GPUs will face stock issues if they end up becoming popular, resulting in the same situation as 5000 series, driving up prices beyond MSRP anyway. The market is starved for a decent GPU release that doesn't go up in smoke right now.
It's like the system is rigged such that consumer's can't score any wins.
Yeah..
Upscaling and FrameGen are last resort for me and with that i don't use any of it, so i don't "add any value" to that, for software to me the Driver UI and features are more important, i was very impressed with AMD's after coming from Nvidia, very nice and lots of useful settings and features, i understand Nvidia have finally released an equivalent but from what i can gather AMD's is still recognised as much better.
RT does matter more to me, it mattered less when i bough the GPU and when you get 27 FPS vs 21 FPS in cyberpunk... well both are unusable even if the 4070 is technically much faster in this instance, the thing is where RT is useable on these GPU's the 4070 isn't a lot better, they are pretty even, this includes Cyberpunk, if you use setting to achieve 60 FPS on the 4070 you get around that or a little less on the 7800 XT using the same settings so the whole thing is contrived and i haven't fallen for it. I do use RT in the games i play that have it and guess what, even at the highest settings it runs well. so.... ¯\_(ツ)_/¯
i do think AMD need to get their RT performance up in these heavy RT games and it looks like with RDNA 4 they have, for me that is far more critical than DLSS / FSR, i find it weird that a lot of people seem to place the FSR vs DLSS problem above the RT problem but ok, whatever... if AMD can get both much closer to Nvidia so that its that much less of a problem then its a win, i want it to get to a stage where people who make these Nvidia added value arguments have to resort back to just saying "because not Nvidia".
Different types of silicon have different transistor density, that's how you can have two chips on same node but with different density. It could be for example that the 9070xt has more memory cache than the 5080 and maybe memory has higher density than GPU cores and perhaps that's why it has a higher density
Or maybe AMD's engineers are just very good at space efficiency and density compared to Nvidia. I don't think the numbers are BS because they come from AMD
I talked about this here...
I would expected that reference cards are perhaps a tad over-engineered in terms of tolerances and components, whereas AIBs for sure strip the fat (and cost, obviously) out of the designs.
They of course add value with beefier coolers etc., but I wouldn't be surprised if the net benefit to the user is neutral at best.
I really like DLSS. If you watch the new HUB video, DLSS 4 has come a long way. To me it is indeed better than native if you have a 4K monitor.
By using it you get a lot more fps which means you can now enable RT. Trouble with AMD at least until now has been FSR has been relatively poor to the point users prefer native. That means struggling with RT and running at much lower fps. That's why given the choice i would take a 4070 over a 7800xt.
9000 series will hopefully change all that.
I really hope FSR4 is at least as good as DLSS 3. That would be a huge step up from FSR 3. What AMD should be doing is assign a small team to get in touch with as many FSR enabled games, especially sponsored ones to update them to FSR 4. That way going forward like DLSS you can just update the .dll file to get the latest version.
With a nice boost in RT plus FSR4, all the 9070XT needs is a nice price and it will sell very well. I don't buy the rubbish the price does not matter. It always matters. Especially at the lower end of budgets which is most people.
If the 9070XT is around 5070Ti performance and it indeed hits $550 I can see it getting glowing reviews almost everywhere.
Yea I hate the state of the gpu market as much as anyone, but saying stuff like "I'd take 1% performance boost over DLSS" in 2025 is like saying "I have a massive bizarre bias and can't be trusted to communicate reliably on this subject".
I can play ACC for the first time now, thanks to the new DLSS.
With that said, Nvidia selling a software patch and a mid-gen refresh as a full blown, stupidly expensive new generation is just IDK, neglect or greed or something
  • Like
Reactions: TNA
I would say greed, good business. But the majority are willing to pay the asking (for the most part), so this is the new normal.
for the AMD 6000 series, absolutely, for this gen we will need to wait because there's some things that are different for this launch.
Typically we have to wait a few days after the full launch before it becomes clear who has engineered what in terms of power phases vram phases and general build quality.
For the 6000 series there were also higher quality vram chips on some of the higher end cards.
Need to remember that power control and power delivery are much more important on a 600w card than they are on a 330 watt card.
Typically, even a cheap 330 watt card will provide less hassle, especially in regards to coil whine and it's ability to set itself on fire.
For this reason, the 9070XT teardowns could look very barebones but that might actually be a good thing in terms of coil whine and reliability.
Lastly, let's not forget that EVGA pulled out of the market for a reason, that main reason being that they didn't feel they could continue to provide what they wanted under the margins Nvidia wanted to pursue. That says a lot about what Asus have had to work with for this gen.
AMDs reference boards has always been overbuild and the reference cooler for the 6000 series were fine/alright. You would have to go back to Vega and before if you wanted an example of poor reference coolers, though they were pretty horrible. As long as AMD don't go backwards in their design or choose to do "an nvidia" and try pull 450+ watts through a single connector then I would have no problem with an reference board and cooler. In some cases I might even prefer it to some of the overpriced hippy designs out there. Regarding coil whine, I've heard that on even top end models so paying more is not a guarantee you wont get it, sadly. There are ways to lessen/remove coil whine which are free regardless of model so I'm not to worried about that personally.
They've said that FSR4 will be upgradeable in games that support FSR3.1. It'll probably be a driver toggle.
Not quite, on-chip SRAM isn't analog, it's digital. It's also the densest way of storing data on-chip as long as your data is the right shape - if you have a deep but narrow memory e.g. 2048 deep x 8-wide. It's less efficient if you have a super wide but shallow array e.g. 8d, 2048w, and there are overheads per RAM macro which mean each process node will have some tipping point where a RAM macro is better than just an array of flip-flops.
The density of the logic (its utilisation) will depend on a number of factors, but these days seems to be mostly wiring limited. If you have to space the cells out to get all the wiring in and out, the cell and therefore transistor density will drop dramatically. Nice regular designs with lots of localised data-flow like CU's are probably pretty decent to layout, but even if they're non-trivial, as they are replicated 1000's of times, you can justify the expense of spending more time/effort optimizing one and then replicating that however many times you need.
