Me, I would prefer a 4090 for some sort of consistency.On the 9800X3D results, would you like a 7900XTX or 4090?
[2025/02/12 09:11:01]
Ai Overclock Tuner [Manual]
eCLK Mode [Asynchronous mode]
BCLK1 Frequency [100.0000]
BCLK2 Frequency [Auto]
Memory Frequency [DDR5-6400MHz]
FCLK Frequency [2200 MHz]
Core tunings Configuration for gaming [Level 2]
Core Performance Boost [Auto]
CPU Core Ratio [Auto]
Core VID [Auto]
CCX0 Ratio [55.50]
Dynamic OC Switcher [Auto]
Turbo Game Mode [Disabled]
Tcl [26]
Trcd [36]
Trp [30]
Tras [62]
Trc [92]
Twr [48]
Refresh Interval [65535]
Trfc1 [384]
Trfc2 [1]
Trfcsb [1]
Trtp [12]
TrrdL [6]
TrrdS [6]
Tfaw [24]
TwtrL [16]
TwtrS [4]
TrdrdScl [5]
TrdrdSc [1]
TrdrdSd [1]
Trdrddd [1]
TwrwrScl [5]
TwrwrSc [1]
TwrwrSd [1]
TwrwrDd [1]
Twrrd [4]
Trdwr [16]
IBUF_LPWR_MODE [Auto]
ADDR_CMD_MODE [Buf]
M_ORDERING [Auto]
S_COL_WIDTH [Auto]
MC_SVA_TRIM0 [Auto]
MC_SVA_TRIM1 [Auto]
MC_SVA_TRIM2 [Auto]
MMCM_MULT_F [Auto]
Read Drift Adjustment P0 [Auto]
Write Drift Adjustment P0 [Auto]
Read Preamble P0 [Auto]
Write Preamble P0 [Auto]
PHY VrefDAC0 P0 Control [Auto]
PHY VrefDAC1 P0 Control [Auto]
PMU DQ Vref P0 Control [Auto]
ARdPtrInitVal P0 Control [Auto]
CA ODT GroupA [Auto]
CK ODT GroupA [Auto]
CS ODT GroupA [Auto]
CA ODT GroupB [Auto]
CK ODT GroupB [Auto]
CS ODT GroupB [Auto]
Processor ODT P state mode [Sync all P-states]
Processor ODT Impedance Pull Up P0 [Auto]
Processor ODT Impedance Pull Down P0 [Auto]
Processor DQ drive strengths Pull Up P0 [Auto]
Processor DQ drive strengths Pull Down P0 [Auto]
Dram ODT Impedance RTT_NOM_WR P0 [Auto]
Dram ODT impedance RTT_NOM_RD P0 [Auto]
Dram ODT impedance RTT_WR P0 [Auto]
Dram ODT impedance RTT_PARK P0 [Auto]
Dram ODT impedance DQS_RTT_PARK P0 [Auto]
Dram DQ drive strengths Pull Up P0 [Auto]
Dram DQ drive strengths Pull Down P0 [Auto]
Proc CS Drive Strength [Auto]
Proc CK Drive Strength [Auto]
Proc CA Drive Strength [Auto]
Proc Data Drive Strength [Auto]
CPU On-Die Termination [Auto]
DRAM Data Drive Strength [Auto]
Rtt Nom Wr [Auto]
Rtt Nom Rd [Auto]
Rtt Wr [Auto]
Rtt Park [Auto]
Rtt Park Dqs [Auto]
Power Down Enable [Disabled]
Memory Context Restore [Auto]
UCLK DIV1 MODE [UCLK=MEMCLK]
CA Tx Phase Shift Clk [Auto]
CS Tx Phase Shift Clk [Auto]
CK Tx Phase Shift Clk [Auto]
CA Rx Phase Shift Clk [Auto]
CS Rx Phase Shift Clk [Auto]
CK Rx Phase Shift Clk [Auto]
FIFO Wr En Fine Delay [Auto]
POC Sample PD [Auto]
Bank Swap Mode [Auto]
Mem Over Clock Fail Count [Auto]
Prochot VRM Throttling [Auto]
Peak Current Control [Auto]
Medium Load Boostit [Auto]
Precision Boost Overdrive [Auto]
Disable Current Limiter [Auto]
Precision Boost Overdrive Scalar [Auto]
CPU Boost Clock Override [Auto]
Per-Core Boost Clock Limit [Auto]
Platform Thermal Throttle Limit [Auto]
Curve Optimizer [All Cores]
All Core Curve Optimizer Sign [Negative]
All Core Curve Optimizer Magnitude [10]
Min Frequency - Low Temperature [Auto]
Min Frequency - Med Temperature [Auto]
Min Frequency - High Temperature [Auto]
Low Frequency - Low Temperature [Auto]
Low Frequency - Med Temperature [Auto]
Low Frequency - High Temperature [Auto]
Med Frequency - Low Temperature [Auto]
Med Frequency - Med Temperature [Auto]
Med Frequency - High Temperature [Auto]
High Frequency - Low Temperature [Auto]
High Frequency - Med Temperature [Auto]
High Frequency - High Temperature [Auto]
Max Frequency - Low Temperature [Auto]
Max Frequency - Med Temperature [Auto]
Max Frequency - High Temperature [Auto]
CO Load Guard [Auto]
VRM Initialization Check [Enabled]
Voltage training [Auto]
CPU Load-line Calibration [Auto]
Segment2 Loadline [Auto]
CPU Current Reporting Scale [Auto]
Core Voltage Suspension [Auto]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Auto]
CPU Power Duty Control [Extreme]
CPU Power Phase Control [Auto]
VDDSOC Current Reporting Scale [Auto]
VDDSOC Switching Frequency [Auto]
VDDSOC Power Phase Control [Auto]
DRAM Switching Frequency [Auto]
DRAM Power Phase Control [Extreme]
MISC Switching Frequency [Auto]
Performance Bias [Auto]
Clock Spread Spectrum [Auto]
BCLK1 Amplitude [Auto]
BCLK1 Slew Rate [Auto]
BCLK2 Amplitude [Auto]
BCLK2 Slew Rate [Auto]
Stretch mode for L3 DFLL [Auto]
Monitoring Software reboot Workaround [Auto]
1.8V PLL Voltage [Auto]
1.8V Standby Voltage [Auto]
Misc_ALW [Auto]
Chipset0 VDD Voltage [Auto]
Chipset1 VDD Voltage [Auto]
CPU 3.3V [Auto]
DDR_testA [Auto]
DDR_testB [Auto]
SMU_Comp1 [Auto]
SMU_Comp2 [Auto]
SMU_Comp3 [Auto]
R1 [Auto]
R2 [Auto]
R3 [Auto]
Sense MI Skew 1 [Auto]
Sense MI Skew 2 [Auto]
Sense MI Skew 3 [Auto]
Sense MI Skew 4 [Auto]
Raise RComp [Auto]
Algorithm 1 [Auto]
Algorithm 2 [Auto]
Algorithm 3 [Auto]
CCD Priority Memory Activity Threshold [1070]
CCD Priority Hysteresis [Auto]
Cooler Efficiency Customize [Keep Training]
Cooler Re-evaluation Algorithm [Normal]
Optimism Scale [100]
CPU Core Voltage [Auto]
CPU SOC Voltage [Manual Mode]
- VDDSOC Voltage Override [1.30000]
CPU VDDIO / MC Voltage [Manual Mode]
- VDDIO Override [1.40010]
Misc Voltage [Manual Mode]
- Misc Voltage Override [1.11000]
VDDP Voltage [1.017]
High DRAM Voltage Mode [Enabled]
DRAM VDD Voltage [1.58000]
DRAM VDDQ Voltage [1.40000]
VDDG CCD Voltage [Auto]
VDDG IOD Voltage [Auto]
PMIC Force Continuous Current Mode [Auto]
PMIC Voltages [Sync All PMICs]
SPD HUB VLDO (1.8V) [Auto]
SPD HUB VDDIO (1.0V) [Auto]
Memory VDD Voltage [1.58000]
Memory VDDQ Voltage [1.40000]
Memory VPP Voltage [Auto]
Memory Voltage Switching Frequency [Auto]
Memory Current Capability [Auto]
Security Device Support [Enabled]
SHA256 PCR Bank [Enabled]
Pending operation [None]
Platform Hierarchy [Enabled]
Storage Hierarchy [Enabled]
Endorsement Hierarchy [Enabled]
Physical Presence Spec Version [1.3]
Disable Block Sid [Disabled]
Firmware TPM switch [Enable Firmware TPM]
Erase fTPM NV for factory reset [Enabled]
Password Protection of Runtime Variables [Enable]
PSS Support [Enabled]
NX Mode [Enabled]
SVM Mode [Disabled]
Above 4G Decoding [Enabled]
Resize BAR Support [Enabled]
SR-IOV Support [Disabled]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
USB Mass Storage Driver Support [Enabled]
USB DISK 3.0 PMAP [Auto]
U10G_C3 [Enabled]
U10G_4 [Enabled]
U20G_C6 [Enabled]
U5G_8 [Enabled]
U10G_9 [Enabled]
U10G_10 [Enabled]
U5G_E1 [Enabled]
U5G_E2 [Enabled]
U5G_E3 [Enabled]
USB_12 [Enabled]
USB_13 [Enabled]
USB_14 [Enabled]
USB_15 [Enabled]
U20G_C18 [Enabled]
U10G_C23 [Enabled]
U10G_20 [Enabled]
U10G_21 [Enabled]
U10G_22 [Enabled]
Network Stack [Disabled]
Device [N/A]
SATA Controller(s) [Enabled]
SATA Mode [AHCI]
NVMe RAID mode [Disabled]
SMART Self Test [Enabled]
SATA6G_1 [Enabled]
SATA6G_1 Hot Plug [Disabled]
SATA6G_2 [Enabled]
SATA6G_2 Hot Plug [Disabled]
SATA6G_3 [Enabled]
SATA6G_3 Hot Plug [Disabled]
SATA6G_4 [Enabled]
SATA6G_4 Hot Plug [Disabled]
Restore AC Power Loss [Power Off]
ErP Ready [Disabled]
Max Power Saving [Disabled]
Power On By PCI-E [Disabled]
Power On By RTC [Disabled]
Native ASPM [Auto]
CPU PCIE ASPM Mode Control [Auto]
PCIEX16_1 Bandwidth Bifurcation Configuration [Auto Mode]
PCIEX16_2 Bandwidth Bifurcation Configuration [Auto Mode]
USB Audio Controller [Enabled]
Realtek LAN Controller [Enabled]
Intel LAN Controller [Enabled]
Wi-Fi Controller [Disabled]
Bluetooth Controller [Disabled]
When system is in working state [Aura Off]
Q-Code LED Function [Auto]
USB power delivery in Soft Off state (S5) [Enabled]
Alteration Mode Switch [PCIE Link Speed]
PCIEX16_1 Link Mode [Auto]
PCIEX16_2 Link Mode [Auto]
M.2_2 Link Mode [Auto]
M.2_3 Link Mode [Auto]
M.2_1 Link Mode [Auto]
Chipset_1 Link Mode [Auto]
SlimSAS Link Mode [Auto]
Chipset_2 Link Mode [Auto]
M.2_5 Link Mode [Auto]
M.2_4 Link Mode [Auto]
Primary Video Device [PCIE Video]
Integrated Graphics [Disabled]
Global C-state Control [Auto]
IOMMU [Auto]
ECC [Auto]
SMT Control [Auto]
App Compatibility Database [Auto]
L1 Stream HW Prefetcher [Auto]
L2 Stream HW Prefetcher [Auto]
L1 Stride Prefetcher [Auto]
L1 Region Prefetcher [Auto]
L1 Burst Prefetch Mode [Auto]
L2 Up/Down Prefetcher [Auto]
Core Watchdog Timer Enable [Auto]
RedirectForReturnDis [Auto]
Power Supply Idle Control [Auto]
Opcache Control [Auto]
Streaming Stores Control [Auto]
Local APIC Mode [Auto]
ACPI _CST C1 Declaration [Auto]
Platform First Error Handling [Auto]
MCA error thresh enable [Auto]
MCA FruText [True]
SMU and PSP Debug Mode [Auto]
PPIN Opt-in [Auto]
REP-MOV/STOS Streaming [Auto]
Enhanced REP MOVSB/STOSB [Auto]
Fast Short REP MOVSB (FSRM) [Auto]
SNP Memory (RMP Table) Coverage [Auto]
SMEE [Auto]
Action on BIST Failure [Auto]
Log Transparent Errors [Auto]
AVX512 [Auto]
MONITOR and MWAIT disable [Auto]
Corrector Branch Predictor [Auto]
PAUSE Delay [Auto]
CPU Speculative Store Modes [Auto]
SVM Lock [Auto]
SVM Enable [Auto]
Latency Under Load (LUL) [Auto]
Memory interleaving [Auto]
Memory interleaving size [Auto]
DRAM map inversion [Auto]
Location of private memory regions [Auto]
ACPI SRAT L3 Cache As NUMA Domain [Auto]
Disable DF to external downstream IP Sync Flood Propagation [Auto]
Disable DF sync flood propagation [Auto]
Freeze DF module queues on error [Auto]
DF Cstates [Auto]
PSP error injection support [False]
Active Memory Timing Settings [Auto]
Processor CK drive strengths [Auto]
Processor CA drive strengths [Auto]
Processor CS drive strengths [Auto]
Processor ODT Impedance Pull Up P1 [Auto]
Processor ODT Impedance Pull Down P1 [Auto]
Processor DQ drive strengths Pull Up P1 [Auto]
Processor DQ drive strengths Pull Down P1 [Auto]
Dram ODT Impedance RTT_NOM_WR P1 [Auto]
Dram ODT impedance RTT_NOM_RD P1 [Auto]
Dram ODT impedance RTT_WR P1 [Auto]
Dram ODT impedance RTT_PARK P1 [Auto]
Dram ODT impedance DQS_RTT_PARK P1 [Auto]
Dram DQ drive strengths Pull Up P1 [Auto]
Dram DQ drive strengths Pull Down P1 [Auto]
Processor ODT Impedance Pull Up P2 [Auto]
Processor ODT Impedance Pull Down P2 [Auto]
Processor DQ drive strengths Pull Up P2 [Auto]
Processor DQ drive strengths Pull Down P2 [Auto]
Dram ODT Impedance RTT_NOM_WR P2 [Auto]
Dram ODT impedance RTT_NOM_RD P2 [Auto]
Dram ODT impedance RTT_WR P2 [Auto]
Dram ODT impedance RTT_PARK P2 [Auto]
Dram ODT impedance DQS_RTT_PARK P2 [Auto]
Dram DQ drive strengths Pull Up P2 [Auto]
Dram DQ drive strengths Pull Down P2 [Auto]
Processor ODT Impedance Pull Up P3 [Auto]
Processor ODT Impedance Pull Down P3 [Auto]
Processor DQ drive strengths Pull Up P3 [Auto]
Processor DQ drive strengths Pull Down P3 [Auto]
Dram ODT Impedance RTT_NOM_WR P3 [Auto]
Dram ODT impedance RTT_NOM_RD P3 [Auto]
Dram ODT impedance RTT_WR P3 [Auto]
Dram ODT impedance RTT_PARK P3 [Auto]
Dram ODT impedance DQS_RTT_PARK P3 [Auto]
Dram DQ drive strengths Pull Up P3 [Auto]
Dram DQ drive strengths Pull Down P3 [Auto]
Power Down Enable [Auto]
Disable Memory Error Injection [Auto]
TSME [Auto]
Data Scramble [Auto]
Chipselect Interleaving [Auto]
Address Hash Bank [Auto]
Address Hash CS [Auto]
Address Hash Subchannel [Auto]
BankSwapMode [Auto]
DFE Read Training [Auto]
DRAM PDA Enumerate ID Programming Mode [Auto]
TX DFE Taps [Auto]
PPT Control [Auto]
DDR Training Runtime Reduction [Auto]
Rx Burst Length [Auto]
Tx Burst Length [Auto]
RX2D_TrainOpt [Auto]
TX2D_TrainOpt [Auto]
RX DFE Taps [Auto]
MBIST Enable [Auto]
Read Drift Adjustment [Auto]
Read Drift Adjustment P1 [Auto]
Read Drift Adjustment P2 [Auto]
Read Drift Adjustment P3 [Auto]
Write Drift Adjustment [Auto]
Write Drift Adjustment P1 [Auto]
Write Drift Adjustment P2 [Auto]
Write Drift Adjustment P3 [Auto]
PCIe ARI Support [Auto]
PCIe All Port ECRC [Auto]
Advanced Error Reporting (AER) [Auto]
PCIe ARI Enumeration [Auto]
UMA Version [Auto]
GPU Host Translation Cache [Auto]
NB Azalia [Auto]
Audio IOs [Auto]
PCIe loopback Mode [Auto]
Persistence mode for legacy endpoints [Auto]
Retimer margining support [Auto]
CPPC Dynamic Preferred Cores [Auto]
TDP Control [Auto]
ECO Mode [Disable]
PPT Control [Auto]
Thermal Control [Auto]
TDC Control [Auto]
EDC Control [Auto]
Fan Control [Auto]
VDDP Voltage Control [Auto]
Infinity Fabric Frequency and Dividers [Auto]
SyncFifo Mode Override [Auto]
Sustained PowerLimit [0]
Fast PPT Limit [0]
Slow PPT Limit [0]
Slow PPT Time Constant [0]
GFXOFF [Auto]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
Chipset 1 Temperature [Monitor]
Chipset 2 Temperature [Monitor]
T_Sensor Temperature [Monitor]
DIMM A1 Temperature [Monitor]
DIMM A2 Temperature [Monitor]
DIMM B1 Temperature [Monitor]
DIMM B2 Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
Chassis Fan 3 Speed [Monitor]
Chassis Fan 4 Speed [Monitor]
Water Pump+ Speed [Monitor]
AIO Pump Speed [Monitor]
CPU Core Voltage [Monitor]
12V Voltage [Monitor]
5V Voltage [Monitor]
3.3V Voltage [Monitor]
CPU VDDIO / MC Voltage [Monitor]
CHIPSET Standby Voltage [Monitor]
CPU Fan Q-Fan Control [PWM Mode]
CPU Fan Profile [Full Speed]
Chassis Fan 1 Q-Fan Control [Auto Detect]
Chassis Fan 1 Profile [Standard]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Step Up [Level 0]
Chassis Fan 1 Step Down [Level 0]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 2 Q-Fan Control [Auto Detect]
Chassis Fan 2 Profile [Standard]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Step Up [Level 0]
Chassis Fan 2 Step Down [Level 0]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 3 Q-Fan Control [Auto Detect]
Chassis Fan 3 Profile [Standard]
Chassis Fan 3 Q-Fan Source [CPU]
Chassis Fan 3 Step Up [Level 0]
Chassis Fan 3 Step Down [Level 0]
Chassis Fan 3 Speed Low Limit [200 RPM]
Chassis Fan 4 Q-Fan Control [Auto Detect]
Chassis Fan 4 Profile [Standard]
Chassis Fan 4 Q-Fan Source [CPU]
Chassis Fan 4 Step Up [Level 0]
Chassis Fan 4 Step Down [Level 0]
Chassis Fan 4 Speed Low Limit [200 RPM]
Water Pump+ Q-Fan Control [Auto Detect]
Water Pump+ Profile [Full Speed]
AIO Pump Q-Fan Control [Auto Detect]
AIO Pump Profile [Full Speed]
Launch CSM [Disabled]
OS Type [Windows UEFI mode]
Secure Boot Mode [Standard]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Fast Boot]
Boot Logo Display [Auto]
POST Delay Time [3 sec]
Bootup NumLock State [On]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
AMI Native NVMe Driver Support [Enabled]
Setup Mode [Advanced Mode]
BIOS Image Rollback Support [Enabled]
Publish HII Resources [Disabled]
Flexkey [Reset]
Setup Animator [Disabled]
Full HD Setup [Enabled]
Load from Profile [3]
Profile Name [6400c26 testin]
Save to Profile [3]
DIMM Slot Number [DIMM_A2]
Hotkey F3 [Toggle ASUS EZ Flash 3]
Hotkey F4 [Boot from UEFI USB]
Download & Install ASUS DriverHub app [Enabled]
Special Display Features [Disabled]
D3Cold Support [Disabled]
Discrete GPU _DSM Function A [Disabled]
Discrete GPU _DSM Function B [Disabled]
NVIDIA DGPU Power Enable [Disabled]
Non-Eval Discrete GPU Support [Enabled]
Discrete GPU HPD Circuitry [OR Circuitry]
Discrete GPU's USB Port [Keep Default Setting]
Discrete GPU's SSID/SVID [Keep Default Setting]
Discrete GPU BOMACO Support [Disabled]
USB4 (ASM4242 Controller) Support [Enabled]
PCIe Bus Number [48]
PCIe Non-Prefetchable MMIO (MB) [384]
PCIe Prefetchable MMIO (GB) [128]
ACPI D3 Support [D3Hot]
XHCI Port0 Speed [Gen2x2]
XHCI Port1 Speed [Gen2x2]
AMD Variable Protection [Enabled]
Processor Aggregator Device [Enabled]
Core Count Control [Enabled]
HDMI 3.0G Tx SLEW [Disabled]
CPU Frequency [0]
CPU Voltage [0]
SMT Control [Auto]
Memory OC Mode [Auto]
Processor DQ drive strengths [Auto]
Processor ODT impedance pull up p0 [Auto]
Dram ODT Impedance RTT_NOM_RD P0 [Auto]
PHY VrefDAC0 P0 [0]
PHY VrefDAC1 P0 [0]
PMU DQ Vref P0 [0]
ARdPtrInitVal P0 Control [Manual]
ARdPtrInitVal P0 [2]
RX DFE Taps [Auto]
TX DFE Taps [Auto]
DDR5 Nitro Mode [Auto]
UCLK DIV1 MODE [Auto]
Fclk VDCI Mode Pref [Auto]
Precision Boost Overdrive [Advanced]
PBO Limits [Motherboard]
Precision Boost Overdrive Scalar Ctrl [Manual]
Precision Boost Overdrive Scalar [10X]
CPU Boost Clock Override [Enabled (Positive)]
Max CPU Boost Clock Override(+) [200]
Platform Thermal Throttle Ctrl [Auto]
GFX Curve Optimizer [Disable]
Curve Optimizer [Per Core]
Core 0 Curve Optimizer Sign [Negative]
Core 0 Curve Optimizer Magnitude [20]
Core 1 Curve Optimizer Sign [Negative]
Core 1 Curve Optimizer Magnitude [25]
Core 2 Curve Optimizer Sign [Negative]
Core 2 Curve Optimizer Magnitude [20]
Core 3 Curve Optimizer Sign [Negative]
Core 3 Curve Optimizer Magnitude [25]
Core 4 Curve Optimizer Sign [Negative]
Core 4 Curve Optimizer Magnitude [25]
Core 5 Curve Optimizer Sign [Negative]
Core 5 Curve Optimizer Magnitude [25]
Core 6 Curve Optimizer Sign [Negative]
Core 6 Curve Optimizer Magnitude [25]
Core 7 Curve Optimizer Sign [Negative]
Core 7 Curve Optimizer Magnitude [25]
VDDG Voltage Control [Auto]
SoC/Uncore OC Mode [Auto]
SoC Voltage [0]
LN2 Mode [Auto]
VDD Misc Control [Auto]
LCLK Frequency Control [Auto]
VDDIO Ctrl [Auto]
Enable Platform PMIC Control [Auto]
VPP Ctrl [Auto]
ECO Mode [Auto]
Writing this post while watching a YouTube video results in 80-90 Watt power consumption while on my 9800x3d system it would be about 125-140 Watt (note that this big of a difference is also due to me utilizing the iGPU on my Intel system because of no downsides in any case).
Something I tried to say, to a certain amount of derision, awhile back. Depending on your usage patterns, the exact configuration of components and efficiency of the PSU, the actual power consumption over a whole day can vary a lot between different platforms. People have been far too lead on in thinking by the power consumption measured at the CPU by various reviewers and the prominence of the CPU fully loaded numbers and have got quite a distorted view of what is actually best for power consumption if you really care about it.
Also, reviewers only test clean installs with modded windows to remove all bloat. Meanwhile when I buy a CPU it goes into a system with a 2 year old install filled with apps and bloat. It's one of the reasons I won't buy an 8 core CPU
@RSR Oh my, average for the Intel build of 685w and then 615w for the 9800x3d based system. It is what it is, and that is rather a lot of power usage indeed...! Albeit, CP 2077 is particularly demanding.
Overall, would you suggest that using either of those systems they "feel" as smooth and responsive as each other..?
Understanding that you previously noted some occasional issues with the AMD platform.
Thanks.
I can confirm the subjective impression that RSR wrote about. Windows feels more stable using the 265k. Particularly some applications like the Roland Bridge Cast App, OpenRGB, HWInfo, etc. open up a lot faster without hitching or anything like that. I actually had the following problem with the 9800x3d opening the Roland Bridge Cast App and closing some apps like OpenRGB: The system would always freeze for some seconds and moving the mouse in that time results in it lagging badly.@RSR Oh my, average for the Intel build of 685w and then 615w for the 9800x3d based system. It is what it is, and that is rather a lot of power usage indeed...! Albeit, CP 2077 is particularly demanding.
Thanks.
I had the 2700x, 5800x3d, 7800x3d and now have the 9800x3d. All of them exhibited/exhibit the same hitches/freezing in opening some application and also sometimes at random. Really annoying.I don't think that is necessarily an AMD vs Intel thing - as some people have noticed post Intel 10th gen and around about the same for AMD there seems to be this thing where some setups, for seemingly no rhyme or reason, have a problem with low level responsiveness (and hitches etc.), one of the reasons I stuck with my Xeon 1650 V2 setup for a long time as my main system due to encountering it on newer 12th and 13th gen Intels and some Ryzen CPUs.
(One such video on it)
Fortunately none of the systems I've built for myself recently including my current main system (14700K) exhibit it. Though my experiences with the 7800X3D so far I noticed there were instances where even just general OS stuff or application installs were less responsive than both my 14700K and even my Lenovo Legion Go when using it in a desktop role! initially I thought it was just the core count difference and generally how they stack up for productivity until I had the Go in the mix which is a 8/16 Zen4 CPU of similar performance to the 5000 series Ryzens - in full power mode it is a touch behind the 5800X.
Deleted quote srry
Asus Z890 Apex
Asrock Z890 OCF
@hlennie These are boards/setup for the Core 200 lineup.
I'm going to go out on a bit of a limb and say the Asrock Z890 OCF is the board you should be looking at for tinkering on the Z890 platform, I've been really very very impressed with it and thus far it has out performed the Apex but the latest Apex bios update may change that.
Asrock Z890 Taichi OCF (LGA 1851) DDR5 ATX Motherboard
Order Asrock Z890 Taichi OCF (LGA 1851) DDR5 ATX Motherboard now online and benefit from fast delivery.www.overclockers.co.uk
As for that money compared to the Apex, it's a steal.
I still need to run tests compared to my AM5 platform as I am using my 9800X3D at the mo but you notice the idle/basic web use power pulled from the wall is higher than that of the 285K systems.
Both Intel systems I had/have which was a 14700k and now the 265k system didn't/don't have this problem.
I don't know if this is just bad luck with AMD CPUs but from my point of view AMDs chiplet design is inferior to Intels monolithic and latest tile (chiplet) design. Intels interconnect (Foveros) seems to be more advanced which allows for higher bandwidth and also keeps the idle power consumption way lower. Latency should also be lower but I've seen reports where it's actually higher than Ryzen 9000 so I don't know.
Gaming wise the 265k is obviously worse than the 9800x3d but about on par with Ryzen 9000 non x3d. I haven't noticed low performance in the games I play. Battlefield 2042 is still at 220 fps and Call of Duty Modern Warfare 3 is at 230-250 fps. Performance in Anno 1800 is basically the same as the 9800x3d.Again, interesting.
Assuming that the 265k now suits better your use I can't imagine that you have noted any particular concerns gaming wise..? Whilst enjoying an overall improved experience applications and other type use.
Did you ever manage to resolve those particular hobnomolies you noted, BIOS updates, chipset drivers, hardware of OS changes etc..? Or was it, largely, something you had accepted whilst having those particular AMD CPU's..?
Thanks.
In regards to the problems with the AMD CPUs I mentioned and what I did: I always updated the BIOS to the latest stable release. Chipset drivers were also always on the latest version. When installing a new CPU I always installed Windows again to have a clean Windows install without any leftovers. I also (in regards to the 7800x3d and 9800x3d) tried different RAM speeds (4800, 5600, 6000, 6400) with no effect apart from idle power consumption being lower by about 10 Watt going from 6400 to 4800 RAM frequency.
