You don't need 10bit for HDR, my OLED screen handles it perfectly well with 8bit+FRC - multiple professional comparisons I've seen online found visible quality to be identical unless it's professional monitor for Hollywood with 500% magnification. In other words, a normal person will never notice any difference and it lowers bandwidth needs considerably.
Thanks for the bonus input / correction of my reference to HDR (I ought to have just stuck with ‘10 bit native’).
I’m honestly not sure how this scales with DSC in Windows in real use but if you configure your monitor to use this way I would assume you could increase your fps limit before you hit your ‘DSC threshold’.
Some monitors also have an option for disabling DSC, so that’s handy - you should just be left with non-DSC options in Windows / NVCP.
