so basically I am better off sitting on my 4090 for the time being then? I was thinking of getting a 5090 but with the problems people are mentioning am not sure now.
So I landed an order for a INNO3D GeForce RTX 5090 X3 32GB at a good price (around the price of a 5090FE) but I do not know anything about this card, and I can't really find any information about it at all. I really hope I won't encounter too much coil whine with it. I ran into it by luck, but I wish I was better informed of what I purchased. Does anyone know about this card at all.
Its the reference model. So basically the 'standard' 5090. I guess most basic, but Inno3d are a good partner brand IMHO. Random sometimes if you get coil whine anyway. I had x2 Palits 3090s and one had horrible coil whine and the other was the quietest I owned.So I landed an order for a INNO3D GeForce RTX 5090 X3 32GB at a good price (around the price of a 5090FE) but I do not know anything about this card, and I can't really find any information about it at all. I really hope I won't encounter too much coil whine with it. I ran into it by luck, but I wish I was better informed of what I purchased. Does anyone know about this card at all.
Thanks. Yeah, hopefully it won't be too bad then. I felt like going for this 3 slot(?) card should probably help with the airflow better than what a 2 slot 5090FE would have done? I dont know. I just hope I did not buy a card that will annoy me to no end. We'll see.Its the reference model. So basically the 'standard' 5090. I guess most basic, but Inno3d are a good partner brand IMHO. Random sometimes if you get coil whine anyway. I had x2 Palits 3090s and one had horrible coil whine and the other was the quietest I owned.
OMFG It's really happening .... Been refreshing my order since the morning and it has moved into processing !!!!!!
Anyone else ?
Holy ****. That's the price of the 5080.![]()
Yeh. No vram increase on the 5080 especially was silly.
The problem for me is, if the 60 series comes out sooner rather than later and the node shrink means we actually get GOOD cards - paying all that money for a 5080 you only keep for a year or two is a real kick in the teeth. You are going to want a 60 series card.
I’d think we wouldn’t see the 60 series until 2027 or tail end of 2026. A couple of years is a long time to hold off…The problem for me is, if the 60 series comes out sooner rather than later and the node shrink means we actually get GOOD cards - paying all that money for a 5080 you only keep for a year or two is a real kick in the teeth. You are going to want a 60 series card.
Life is short. Options are limited. I need 60fps minimum and I need it now.The problem for me is, if the 60 series comes out sooner rather than later and the node shrink means we actually get GOOD cards - paying all that money for a 5080 you only keep for a year or two is a real kick in the teeth. You are going to want a 60 series card.
