It's America. So 100% I'd imagine so. Just no jenson woosh sound effects.
Is Lisa Su going to be there? Hopefully she is and dons the leatherest of jackets.
So if the Reaper is 304mm length and my old Red Devil 5700XT (pictured below) was 300mm in length..
Here is the gap I have left for the Reaper if I want to keep the rad at the front of my case
It should squeeze in there but its tight! Dare I risk it?
Is Lisa Su going to be there? Hopefully she is and dons the leatherest of catsuits.
Born in ‘75, the 90’s were my playground. Glow sticks and disco biscuits at every opportunityMaybe because I am a teenager of the 90s and the rave scene but I still love all those sparkly RGB lights
Yeah. Looking back I could have killed a herd of elephants with that consumption. At least I lived to tell the tale.Born in ‘75, the 90’s were my playground. Glow sticks and disco biscuits at every opportunity
if we are really lucky we will get 1 hour with some AMD product dude talking about 3d audio. I am not joking.It's America. So 100% I'd imagine so. Just no jenson woosh sound effects.
Anyone who has a previous power color red devil, are the lights changeable from red ? Can I add a nice tacky rainbow effect ?
why watercool a nitro - buy the cheapest decent quality brand and plonk a waterblock on that. no point buying a high end card and ripping the cooler off of it.![]()
SAPPHIRE Radeon RX 9070 XT NITRO+ pictured in the flesh: 16-pin power connector confirmed - VideoCardz.com
NITRO+ RDNA4 graphics card uses a 16-pin power connector Not all RX 9070 cards will use standard connectors. NITRO+ RX 9070 XT, Source: Chiphellvideocardz.com
16 pin power connector on the saphire radeon rx9070 xt nitro. I was planning to buy and watercool this. Now its not worth the risk at all.
Though I don't like the connector, I think it's only an issue with cards that nearly max the capacity of it.![]()
i now can't stop 'saying' this in my head....thanks.faster in raster
AMD always does this though and price the lower performing card worse, 7900XT vs 7900XTX, 7800XT vs 7700XT for example both the lower models had worse price to performance.At those prices it converts to $599 for the XT and $539 for the non XT.
XT if trading blows with a 70Ti, that is a big win. You would be paying 25% more for similar performance for the Nvidia GPU. It will be even more massive if there is enough stock for that to be a realistic price for the base models.
The non XT seems like a missed trick and I assume would miss the 20% better price perf over a 5070, if all the perf leaks for both GPUs are accurate. But it should be noted that the 9070 does have 4GB more VRAM (no GDDR 7 won’t make a difference). Though getting under that $500 price point on the 9070 would have been massive.
$539 for the 9070 is so so and just too close to the 5070 expected price/perf but the extra VRAM helps a bit. Seems like they are upselling people to the XT and to be fair, I can understand why because $599 is a genuinely great price for the level of performance.
