Nah, not even close.
Zzzzzzzz they'd have to be giving them away for some people to be happy
So did AMD score a goal today?![]()
5070ti ordered? hope it wasn't too much above £800Nah, not even close.
I'm aware of that as I'm sure everyone is.The 5080FE overclocks+undervolts really well past stock levels, though. Not the best comparison
I must have missed that, in their slides I saw the 9070 and xt compared against 3080 and 3090 respectively. Thanks.They compared the 9070xt to the 5070ti
To quote yourself in another thread
"Give it a few months, the 5070 Ti won't have the persistent supply issues of the 5090. This will be a good deal at $750 and will be the GPU to buy - enough VRAM until the new consoles push reqs further, and plenty of performance + a killer feature set. Only way I can see anything else touching it is if AMD decides to launch the 9070 XT at $600, but even that's probably not enough (and AMD won't do it anyway)"
For example, compared to the 7900 XTX, Team Red is showing off much better quality while encoding H.264 (AVC) at 1080p using 6 Mbps bitrate. Speaking of H.264, the new media engine also improves low-latency H.264 encoding at lower bitrates.
In the case of HEVC (H.266), AMD claims an 11% encode quality improvement. AV1 is also seeing encoding efficiency improvements thanks to B Frames. Up to 8K 75 fps encoding is supported for HEVC and AV1, says AMD.
Aside from encoding improvements, decoding is also set to see some big gains. The company says the new VCN version brings low-power video playback with "more than 50% performance uplift for AV1 and VP9". This can be pretty significant since a lot of major web content is on VP9 or AV1. Not much is mentioned about H.264 and H.265 though. Perhaps the company feels there isn't much room for optimization for these codecs.
Another 16pin Hpwer connector for top of the line model.![]()
ASRock Intros Radeon RX 9070 Taichi, Steel Legend & Challenger GPUs: 9070 XT Up To 3.1 GHz Clocks, 16 Phase & 16-Pin Power Connector
ASRock has introduced its next-gen Radeon RX 9070 lineup with Taichi, Steel Legend & Challenger series, and up to 3.1 GHz clocks on 9070 XT.wccftech.com
ASRock > Graphics-Card
www.asrock.com
HUB saying AMD didn't go low enough vs nvidia. Marketshare will go nowhere if nvidia get supply going and msrp cards land.
