Never trust any elevation estimate. They are wildly off. Easily by 50%+ at times.
Yeah. Nothing worse than the Garmin climb pro telling you you've only got 5m climbing to go when you can see the top and know there's a lot more to go!
I always find it funny to see the number of people who are out dressed for a Siberian winter when its like 5-10 degrees. Especially at the tail end of the Autumn.
Cycling around here and seeing the locals you'd think it was -20C somedays!
Hope you're keeping up with the commuting?! If you didn't grab a track pump yet then it's worth investing in a good one. My Joe Blow (v1) is one of the best I've ever owned and is 9 year old after I'd been buying a new cheap one every 12 months before.Need to pick me up a cheap track pump from market place, i used to borrow my mates, i have a small pump which i tend to use.
Big difference between 25mm and 28, I imagine the change to 30mm is good too... But going from 25mm to 32mm would be massive! In my opinion and depends on tyres, but too much. They'll feel too different and likely slow.I've been running around on my cx bike with 33mm and pu tubes, and even that is pretty horrible with the stare of the current roads. I've got a 2024 tcr with the standard 25s, will need to wear them out before chucking on some 32s.
Seems expensive for what is quite an old/traditional design (limited internal routing from the downtube) with a new groupset thrown on it... But is Ti I guess so that bumps the price, so compared to other Ti builds it's actually well priced. But not convinced they're actually made in the UK!?https://gloriacycling.com/products/all-road-105-dt-swiss-wheelset looks like a very nice bike.
What makes you think you don't? Especially if building yourself. You still gotta set it up and index occasionally (although it is a far amount less)!cue all the jokes at my expense but last night my bike wasn't shifting in from the small ring into the big ring.
And my first thought was "I wouldn't have to deal with this crap with DI2"![]()
Wax won't help much with mud/water/salt, if anything it's worse around salt than a wet lube as you'll get a rusty chain rather than a gloopy black one.pretty sure pot-holes are responsible for this damage on rubino pro4 graphene ?
With salt&mud on Cambs roads would wax help on the chain - over drylube,
Having to take the jockey wheels off to for a clean it's just as tedious to toothbrush scrub whole chain in hot degreaser, then rinse - I'm not convinced any clip on chain cleaner would be as efficient
Mega price - when you consider I built my 'hodge podge' of Di2's older generations together over several years and paid in total a bit less than that (£700 & £730)...EDIT - Even better this place is Bristol based for you
Shimano 105 R7170 12 speed Di2 groupset for disc brake
Shimano 105 R7170 12 speed Di2 groupset for disc brake Free Shimano 105 PD-R7000 pedals with this grouspet during April 2026 Genuine boxed Shimano components fully guaranteed The new SHIMANO 105 brings Di2 shifting to a new set of riders. For those who have only experienced mechanical shifting...www.veloworkshop.co.uk
Hope you're still feeling good mate and the rest day helped - never underestimate the need for rest, especially when mixing up sports or increasing volume. Whoop recovery comes from HRV so sometimes it can be a bit misleading, but with the high day strain just shows how much you worked across everything combined. It might have been the ride a little harder than normal, or other factors too!My Whoop had been slow updating and finally did so this morning. Yesterday's effort was 20.3, which is the highest in 6 months (which includes two Spain trips, taking on 2k+ ft climbs) and my recovery today is Red, which not including Covid, has only happened once in 6 months (during one of the Spain trips)
Great weekend! 50 miles on Saturday and 70 yesterday. My god the roads of Herefordshire are shocking. Literally craters, not just potholes! Summer is going to be fun with all the pointing!
Oh it's all habit and practice, but you generally signal before a hole/rough part, not when you're on it... Although depends on your ability and confidence too. If I know the road/hole or on front I'll ride a gap so I can skip to the side, or ride through a rough bit knowing I'm Tubeless while signalling. But I do tend to ride wider tyres and lower pressures that most with much lower risk of a pinch causing any issue. If the group is tight I'll happy 'take one for the team' being Tubeless... As many I ride with are on tubes and riding older setups.This is what would worry me about group rides. I wouldn't feel remotely confident taking one hand off the bars to give hand signals in some places because the general quality of the roads is shocking, let alone when you are trying to avoid potholes.
yeah, the bikes are assembled in uk but frame is welded/put together in a china which is somewhat annoying even tho I have nothing against quality stuff from china, I'd still like to buy a "dream" bike that I can upgrade in the future..Seems expensive for what is quite an old/traditional design (limited internal routing from the downtube) with a new groupset thrown on it... But is Ti I guess so that bumps the price, so compared to other Ti builds it's actually well priced. But not convinced they're actually made in the UK!?
So something like this:
Tbf, there are a few metrics it uses. HRV, RHR, Skin Temp, Respiratory Rate and Blood Oxygen. Four of those are still the wrong side of things at the moment, although right now it seems to be my stomach that's a concern to me...Whoop recovery comes from HRV so sometimes it can be a bit misleading
I managed 1400m in 80km yesterday. I need to up it. I have the marmotte in JuneI really need to start doing more elevation in my rides! I did a flat 47km (~170m of elevation) on Sunday. Was quite funny as I left at about 8am when it was nice but still cold. By the time i was getting home you could tell it had warmed up as more people were heading out in just shorts and short sleeve jerseys/gilets!
I managed 1400m in 80km yesterday. I need to up it. I have the marmotte in June![]()
Ah fair enough, especially at that price! I just recall spending £18-25 on cheap pumps and they never lasted... Then snagged the Topeak on a deal for only a few quid more and the quality/build was worlds apart. Especially now it's 9 years old!
The Roubaix is a great bike. It's basically what I'm riding - my early Diverge being a road setup. But I can never get away from the 'block' look at the rear of the seattube above the seatstays. That annoys me and don't know why it's there (there's no insert or 'futureshock' in the seattube)! The way Cannondale have done the one on the Supersix - where it drops down lower below the seatstay join looks so much better!
that Triban is nice, more modern design. Lots of talk about Van Rysel at the moment, would keep an eye out for them doing a more racey endurance version?!
Guy in my club is selling a 'Mark Reilly gravel ti frame'. I'm trying to get some info which it is as quite tempted myself...
I'd recommend a loop when visiting the Mendips something like...For me I feel like I have to cycle to Bath before any good hills begin (Bannerdown being my favourite but Midford hill is quite fun too) we have a few hills that are a bit closer like Dundry but it means riding though the arse end of town which isn't pleasant.
Really it's Zwift I get to use for elevation.
I got my baby-sportive in 2 weeks. Once that's done I'm going to finally give Cheddar Gorge a try
Up Burrington Coombe
Down Draycott's New Rd (make sure your brakes work first, hits ~20% for ~0.5 miles!)
Up Cheddar
Roughly, you'd be looking at ~50 miles with ~3200 feet climbing from near Bristol Temple Meads station.
Ooooh didn't know it used all of them, have to admit the only one of those I occasionally see a message about is skin temp being outside of norm. So don't really take much notice - the 'AI' thing always warns me about HRV being low for any low Recovery - don't think it mentions the others!? Or is that it - if they where the cause it would...Tbf, there are a few metrics it uses. HRV, RHR, Skin Temp, Respiratory Rate and Blood Oxygen. Four of those are still the wrong side of things at the moment, although right now it seems to be my stomach that's a concern to me...
Still a good amount! Got some Zwift club friends off to Amstel and one of them buried himself 2 weekends ago and is now stressing he had to take a week 'easy' (still 200 km of Zwifting) to recover, but see he did 137km this weekend including the Muur, Berendries and Bosberg! Very jealous about where he lives and have an open invite... Even quite tempted to go ride Amstel as a 'pirate' with them (it's open roads)!I managed 1400m in 80km yesterday. I need to up it. I have the marmotte in June![]()
Last ones I got from PX as cheapest but that was a long time ago as don't bother with it now. I mostly used it for seating tricky tubeless tyres...co2, where do people get theirs from? Realised I'm down to a single and off to Majorca on Saturday, so need some sharpish.
Wookey Hole seemed a glorious place to ride when we visited there last summer. Considering the weather and where it is, the roads seemed quiet & fantastically rolling!Yeah if you go past BTS and up Wells road you get to go up Dundry which feels like a wall at the start! But you get to go around a nice big reservoir before heading off to Cheddar.
I've got a couple of routes I've stole from a local cycling club. Both are about 100km that go to Wookey Hole and the other Cheddar. Just need to man up and do them solo.
I think a lot of my issue is the longer, further from home rides, i enjoy doing with a friend for the social side but then when I get let down I don't have the cajones to go solo
You know you can get strava to auto adjust it?funny thing, I got a route from komoot that I did on saturday - 50k only.
komoot said 320m climbing
garmin said 290m climbing
real? 470m. I have trust issues now. I hate climbing too.
The numbers are correct, that’s what Garmin logged too after calibrating from start point. It’s just the elevation difference between planning apps that’s oddYou know you can get strava to auto adjust it?
