So case arrived today Flux Pro. I have some feedback after transferring stuff from old case.
The Good:
Real nice case to work on.
Cable management is great.
Loads of space.
Very quote and cool - I’m mean crazy good.
The Bad:
The metal is fin and bendy. You can feel it. I certainly did from 011D XL.
The motherboard tray on my case was bent. The case needed some small bending to allow the motherboard to mount correctly. I thought stand offs for a time but no the tray was bent.
This is may feedback. Others may of had a better experience.
The Good:
Loads of space.
The Bad:
Perhaps some fan shrouds I could fix set to one colour for instance?
in beige
