*** The AMD RDNA 4 Rumour Mill ***
What’s the thoughts on us seeing a 9070XTX?
Do AMD have something cooking away? I know they’ve said their concentrating on midrange this time round but there’s been a few rumours circulating
I think they do.... i think they have a 32GB version in the oven for those bargain workstation / AI accelerator people "oh its got 1550 TOPs" why do i as a gamer care????? you didn't bother to print the TOPs on the box of the 7000 series....
Doesn't that only apply to vRAM which actually has ecc enabled? I know some previous generation series had ecc, but then GPU makers started to reserve it again just for pro cards, so it's possible none of the new GPUs have that on and then stability (and visible errors) could be the sign again. I know my 4090 by default has it turned off as it's slowing down vRAM somewhat when it's on and has to be turned on in drivers to work.
You are correct. It’s not ECC that is used in gaming GPUs, it’s EDR (Error Detection and Replay). Basically if the GPU detects an error, it resends the data… hence the noticeable drop in performance. I can see exactly this behaviour on my 7900 XT and what we are seeing in that video is the exact behaviour we would expect with VRAM being clocked too high.
You are correct. It’s not ECC that is used in gaming GPUs, it’s EDR (Error Detection and Replay). Basically if the GPU detects an error, it resends the data… hence the noticeable drop in performance. I can see exactly this behaviour on my 7900 XT.
Mine just crashes if i push it over 2600.
Because it’s not full on ECC.
Nether is yours and you're not "seeing exactly this behaviour on your 7900 XT" just as i aren't. Because it’s not full on ECC.
This guy is normally very good but his take on VRAM overclocking is an epic fail. The VRAM has error correction to prevent crashes. So high clocks cause instability and the GPU compensates by reducing the actual performance.
The way to OC VRAM is to keep going until your performance actually regresses, then reduce the OC slightly for extra stability. Keep your VRAM out of the error correction state.
EDR makes sense, that's usually not even shown in specs, though we had for a while ECC too. At least they have EDR now, in the past there was nothing, just crashes.
I’m not getting into a pointless debate on semantics with you. My post was a quick outline to why overclocking VRAM beyond limits results in the behaviour seen in the video. And indeed with my experience. The fact yours crashes does not remotely make that point wrong.
The 9070XT is using the full Navi 48 and AMD aren't doing a bigger GPU until RDNA5/UDNA.
We could see a 9070XT+ with higher power limits, Clocks and more memory but this so far is just rumour.
It's a midpoint—it can correct errors, but it's highly inefficient at doing so. And once you go beyond a certain threshold, ECC or not, it won't be of any help. :P
Yep, this is exactly what it does. But ultimately my point was to explain the “why” without getting too deep in to the technicalities. I obviously failed because some people want to argue semantics :D
Truly shocking revelations here, folks! Some people… arguing about semantics?! We never saw this coming. Experts say it was only a matter of time before a discussion turned into a meticulous dissection of word choice. More at 10—see you in the studio.
In other news, haters gonna hate!
