What time do we expect these to go live for purchase on March 12?
According to AMD marketing the 9950X3D is faster than the 9800X3D in games.
Hoping these will be freely available on launch.
www.techspot.com
Hard to imagine the 9950X3D ( or 9900X3D ) will be significantly faster than a 9800X3D at gaming. After all, one of the CCD's in the 9950X3D is in essence a 9800X3D. If the higher base clock frequency is maintained, then the 9950X3D could be fractionally faster, but if core "parking" is still an issue then that ( along with the added latency between the two CCDs ) could make it fractionally slower.![]()
AMD admits the Ryzen 9 9950X3D may not be faster than the 9800X3D in gaming
In an interview with VideoGamer, AMD's product and business development manager, Martijn Boonstra, revealed that the 9950X3D and 9900X3D will deliver "similar overall gaming performance" to the...www.techspot.com
It seems it might be blows traded each way, bit likely only by the 9950 not the 9900
How does gaming work on the 9900X3D (for example) given that both CCDs have 3D V-Cache? Does gaming workload span across both chiplets now?
As above, it's only one 3D cache core isn't it?How does gaming work on the 9900X3D (for example) given that both CCDs have 3D V-Cache? Does gaming workload span across both chiplets now?
I'm guessing it's some technical limitation but I wonder why they do 2 6 core ccds instead of an 8 core and a 4 coreAs above, it's only one 3D cache core isn't it?
It's a hard sell, same with the 7900X3D, as only 6 cores for gaming is likely to be an issue in the near future.
Core parking wasn’t an issue as long as you followed the correct steps when installing the drivers etc.Hard to imagine the 9950X3D ( or 9900X3D ) will be significantly faster than a 9800X3D at gaming. After all, one of the CCD's in the 9950X3D is in essence a 9800X3D. If the higher base clock frequency is maintained, then the 9950X3D could be fractionally faster, but if core "parking" is still an issue then that ( along with the added latency between the two CCDs ) could make it fractionally slower.
Sorry, have to disagree on this. Later BIOS updates improved the situation, but it was still an issue for many people. A quick Google search or trawl through Reddit etc is proof.Core parking wasn’t an issue as long as you followed the correct steps when installing the drivers etc.
Haven't seen anything official, but that's the configuration of both the 7900X3D / 9900X and as far as we're aware the only real change in the architecture is how the 3D V-cache is implemented.Have AMD definitely confirmed the 9900x3d will be 2x 6c and not 1x 8c and 1x 4c?
I owned the 7950x3d and had no issues. Game bar enabled, balanced power plan, chipset drivers (from AMD website) and make sure game bar is updated. Every now and then you might have to tick a box “remember this is game”.Sorry, have to disagree on this. Later BIOS updates improved the situation, but it was still an issue for many people. A quick Google search or trawl through Reddit etc is proof.
It seems it might be blows traded each way, but likely only by the 9950 not the 9900
