- 10 Sep 2006
- UK
Looks like there's basically zero weaknesses with the 9950X3D
www.kitguru.net
I was hoping to get 2x Gen 5 m.2s for the x870-e Hero. Unfortunately only one Gen 5 and one Gen 4 is possible without limiting to 8x from my understanding.
Not the greatest move.
AMD Ryzen 9 9900X3D Review - KitGuru
AMD announced the Ryzen 9 9900X3D at CES 2025 which allies twelve cores of Zen 5 goodness with a slawww.kitguru.net
Says
9900x3d £600
9950x3d £700
Thinking doing the extra step up and getting the 9950x3d and then not worry about a CPU for a few years
Like I did with my i7 5960x, the last CPU I brought my self 10 years ago
Problem is, I now feel my 5070ti and 32gb ram is under kill and need upgrading![]()
Would put it £40 cheaper than the 7950x3d that ocuk is currently taking pre-orders for.Should be £650 after conversion and VAT
It’s not the point. You should be able to use 2x gen 5 without it affecting lanes.You'd need to be moving files about to get any benefits of Gen5 just now. I'd bet you'd not tell the difference between the two gen4 and gen 5 in day to day general use.
I'm assuming they're just not as exciting, the 9950X3D is what we expected so the 9900X3D probably will be too, i.e. slower than a 9800X3D in gaming by a bit but mostly faster in multithreaded stuff.
The 9550x cost £70 more there than OC. I have noticed the 9550x is £50 cheaper at the purple shop than at OC. Think I've made a mistake and put my order in too soon. I was waiting for the 9550x3D I didnt know it was out so soon so I ordered the 9550x with all my other stuff about 10 days ago 2 items are still on pre-order so it might be just best for me to cancel the 9550x and order the 3D when it's in stock.The orange place has 9950x3d on sale for £780
9900x3d listed as coming soon as well on same site
Who knows.. no communication by OCUKWill these be up for sale/preorder at 1400 tomorrow?
@Gibbo has been tagged but is probably unsurprisingly busy as monitoring the forums isn't exactly his jobWill these be up for sale/preorder at 1400 tomorrow?
Or 'Smack my b****s up'AMD might as well just called it The Daddy
