That's the one I had prior to my AliExpress one, compared to that, the AliExpress one is leagues better.This is the one I use on my Nilfisk. Basic as you like, but works like a charm - Amazon
£10 more than AliExpress, but you'll get it tomorrow instead of sometime in May.
does for me, out to wazoo, but delivering it from a mundane 5L garden sprayer gave similar results, plus don't want to look too geeky to the adult neighbours.It won't make mountains of thick foam for pretty Instagram pictures but it will do an actual job.
I can't figure out what any of this is meant to meandoes for me, out to wazoo, but delivering it from a mundane 5L garden sprayer gave similar results, plus don't want to look too geeky to the adult neighbours.
(taking the wheels off the car for separate washing was already enough) - it is a strictly karcher only neighborhood though, the height of ...
Depends what you class as "costing millions" a really good foaming... foam.. is Autobrite Direct - Magifoam, around £30 for 5 litres, 150/200ml topped up with warm water will foam amazing... a decent foam lance will also make all the differenceYep it's not great. Thanks I'll check it out
Also what liquid snowfoam are people using? I want something that foams well, doesn't cost millions and comes in good quantity bottle
Interesting. I've got no complaints with mine so never thought what would make it better? Soap goes in, foam comes outThat's the one I had prior to my AliExpress one, compared to that, the AliExpress one is leagues better.
In fairness my aliexpress one replaced my several years old one that you linked, but the foam is much thicker at the same dilution rate.Interesting. I've got no complaints with mine so never thought what would make it better? Soap goes in, foam comes out![]()
If you do get an AVA, make sure you register the warranty. I didn't and now it's out of warranty after 2 years. Very annoying but they do have a very useful aftersales team if you need parts. Their spares are sold at cost and they also provide guides on replacing parts.No it’s pants IMO. I’ve used cheaper ones which have been better
Thankfully it uses the Karcher attachment so you can get a lot of cheap lances which are decent.
maybe expand your vocabulary "Out to wazoo" is a slang expression meaning "to a great or excessive degree" or "in abundance". ie lot's of foam bh contactlessI can't figure out what any of this is meant to mean
I've always washed my cars myself and I'm slowly getting into better habits with things like clay bars and coatings (other than waxing), but I've never 'washed' my tyres. I picked up a spray to dress them the other day. What's the process for getting the most out of it?
I believe I did but very good pointIf you do get an AVA, make sure you register the warranty. I didn't and now it's out of warranty after 2 years. Very annoying but they do have a very useful aftersales team if you need parts. Their spares are sold at cost and they also provide guides on replacing parts.
maybe just post in normal English so people don't need a degree in cryptography to figure out what on earth the word salads you're spewing out might mean[
I've never specifically "washed" my tyres, a quick pressure wash when doing the rest of the car is normally sufficient. Then apply tyre dressing after finishing washing the rest of the car.
If you want something that helps clean the car well, BiltHamber Touch-less is hard to beat. It won't make mountains of thick foam for pretty Instagram pictures but it will do an actual job.
